首页 论坛 原厂专区 TI MCU 效率为 98.6% 且适用于 HEV/EV 车载充电器的 6.6kW 图腾柱 P
[分享] 效率为 98.6% 且适用于 HEV/EV 车载充电器的 6.6kW 图腾柱 P
1141 查看
13 回复
 楼主 | 发布于 2018-08-30 | 只看楼主
效率为 98.6% 且适用于 HEV/EV 车载充电器的 6.6kW 图腾柱 PFC 参考设计
(1 ) (1 )
楼主 | 回复于 2018-08-30 沙发
This reference design functions from a base of silicon carbide (SiC) MOSFETs that are driven by a C2000 microcontroller (MCU) with SiC-isolated gate drivers. The design implements three-phase interleaving and operates in continuous conduction mode (CCM) to achieve a 98.46% efficiency at a 240-V input voltage and 6.6-kW full power. The C2000 controller enables phase shedding and adaptive dead-time control to improve the power factor at light load. The gate driver board (see TIDA-01605) is capable of delivering a 4-A source and 6-A sink peak current. The gate driver board implements a reinforced isolation and can withstand more than 100-V/ns common-mode transient immunity (CMTI). The gate driver board also contains the two-level turnoff circuit, which protects the MOSFET from voltage overshoot during the short-circuit scenario.
楼主 | 回复于 2018-08-30 2#
  • High-power-density, high-efficiency PFC design to power systems up to 6.6 kW
  • Half-bridge- and compact isolated gate driver with reinforced isolation and two-level turnoff protection
  • Full digital control with high-performance C2000™ controller to enable advanced control scheme
  • 98.46% peak efficiency, greater than 0.99 power factor and less than 2% total harmonic distortion (THD)
  • Three-phase interleaved operation with phase shedding control
回复于 2018-08-30 3#
这个好,感谢分享
回复于 2018-08-31 4#
回复于 2018-08-31 5#
回复于 2018-08-31 6#
回复于 2018-09-04 7#
回复于 2018-09-15 8#
支持下,谢谢分享
回复于 2018-09-19 9#
回复于 2018-09-23 10#
