[行业活动] LPS22HBTR:piezoresistive absolute pressu
930 查看
 楼主 | 发布于 2018-08-08 | 只看楼主
The LPS22HB is an ultra-compact piezoresistive absolute pressure sensor which functions as a digital output barometer. The device comprises a sensing element and an IC interface which communicates through I2C or SPI from the sensing element to the application.
The sensing element, which detects absolute pressure, consists of a suspended membrane manufactured using a dedicated process developed by ST.
The LPS22HB is available in a full-mold, holed LGA package (HLGA). It is guaranteed to operate over a temperature range extending from -40 °C to +85 °C. The package is holed to allow external pressure to reach the sensing element.
Key Features
  • 260 to 1260 hPa absolute pressure range
  • Current consumption down to 3 μA
  • High overpressure capability: 20x full-scale
  • Embedded temperature compensation
  • 24-bit pressure data output
  • 16-bit temperature data output
  • ODR from 1 Hz to 75 Hz
  • SPI and I²C interfaces
  • Embedded FIFO
  • Interrupt functions: Data Ready, FIFO flags, pressure thresholds
  • Supply voltage: 1.7 to 3.6 V
  • High shock survivability: 22,000 g
  • Small and thin package
  • ECOPACK® lead-free compliant
楼主 | 回复于 2018-08-08 沙发
自己支持下;
回复于 2018-08-08 2#
多谢分享!!!!
回复于 2018-08-11 3#
谢谢分享!!!!!!!!!!!
回复于 2018-08-11 4#
回复于 2018-08-29 5#
感谢楼主分享
