[行业活动] LSM303AHTR:3D digital accelerometer, 3D
679 查看
 楼主 | 发布于 2018-08-08 | 只看楼主
The LSM303AH is an ultra-low-power high-performance system-in-package featuring a 3D digital linear acceleration sensor and a 3D digital magnetic sensor.
The LSM303AH has user-selectable linear acceleration full scales of ±2g/±4g/±8g/±16 g and is capable of measuring accelerations with output data rates from 1 Hz to 6400 Hz. The device has a magnetic field dynamic range of ±50 gauss with output data rates from10 Hz to 100 Hz. The LSM303AH includes an I2C serial bus interface that supports standard, fast mode, fast mode plus, and high-speed (100 kHz, 400 kHz, 1 MHz, and 3.4 MHz) and an SPI serial standard interface.
The LSM303AH has an integrated 256-level first-in, first-out (FIFO) buffer allowing the user to store data in order to limit intervention by the host processor. The FIFO buffer applies only to the accelerometer.
The embedded self-test capability allows the user to check the functioning of the sensor in the final application.
The system can be configured to generate an interrupt signal for free-fall, motion detection and magnetic field detection. The magnetic and accelerometer blocks can be enabled or put into power-down mode separately.
The LSM303AH is available in a plastic land grid array package (LGA) and is guaranteed to operate over an extended temperature range from -40 °C to +85 °C.
Key Features
  • 3 magnetic field channels and 3 acceleration channels
  • ±50 gauss magnetic dynamic range
  • ±2/±4/±8/±16 g selectable acceleration full scales
  • Anti-aliasing filter
  • 16-bit data output
  • SPI / I2C serial interfaces
  • Analog supply voltage 1.71 V to 1.98 V
  • Programmable interrupt generators for free-fall, motion and magnetic field detection
  • Embedded self-test
  • Embedded 256-level FIFO
  • Embedded temperature sensor
  • Embedded digital functions: step detector, step counter, significant motion and tilt
  • ECOPACK®, RoHS and “Green” compliant
楼主 | 回复于 2018-08-08 沙发
楼主 | 回复于 2018-08-08 2#
自己支持下;
回复于 2018-08-08 3#
多谢分享!!!!
回复于 2018-08-08 4#
回复于 2018-08-11 5#
回复于 2018-08-29 6#
感谢楼主分享
