[原创] TMS320C6678开发例程使用手册(10)
366 查看
 楼主 | 发布于 2020-06-30 | 只看楼主
3.4.2硬件测试(禁用缓存及使用缓存)
修改main.c文件中的代码可选择硬件测试模式,如下图所示:
重新编译之后,使用仿真器连接开发板,进入仿真状态,加载编译好的.out文件,执行得到如下结果:
 [C66xx_0]
Test signal
-Include 2V DC Component
-Include 3V AC Component,Frequency:50Hz Phase:-30 Degree
-Include 1.5V AC Component,Frequency:75Hz Phase:90 Degree
-Formula:y=2+3cos(2pi*50t-(30/180)pi)+1.5cos(2pi*75t+*(90/180)pi)
--------------------------- Cache Disabled ---------------------------
1: 16 Point FFT Test
-Sampling Period:1s Sampling Frequency:16Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 7558
-Forward Transformation Execution Time is 7.5580000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 7442
-Inverse Transformation Execution Time is 7.4420000 us (CPU Frequency:1000MHz)
16 Point FFT Test End
2: 32 Point FFT Test
-Sampling Period:1s Sampling Frequency:32Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 9380
-Forward Transformation Execution Time is 9.3800000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 9678
-Inverse Transformation Execution Time is 9.6780000 us (CPU Frequency:1000MHz)
32 Point FFT Test End
3: 64 Point FFT Test
-Sampling Period:1s Sampling Frequency:64Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 19494
-Forward Transformation Execution Time is 19.4940000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 20236
-Inverse Transformation Execution Time is 20.2360000 us (CPU Frequency:1000MHz)
64 Point FFT Test End
4: 128 Point FFT Test
-Sampling Period:1s Sampling Frequency:128Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 35840
-Forward Transformation Execution Time is 35.8400000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 37002
-Inverse Transformation Execution Time is 37.0020000 us (CPU Frequency:1000MHz)
128 Point FFT Test End
5: 256 Point FFT Test
-Sampling Period:1s Sampling Frequency:256Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 83414
-Forward Transformation Execution Time is 83.4140000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 86428
-Inverse Transformation Execution Time is 86.4280000 us (CPU Frequency:1000MHz)
256 Point FFT Test End
6: 512 Point FFT Test
-Sampling Period:1s Sampling Frequency:512Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 164924
-Forward Transformation Execution Time is 164.9240000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 168962
-Inverse Transformation Execution Time is 168.9620000 us (CPU Frequency:1000MHz)
512 Point FFT Test End
7: 1024 Point FFT Test
-Sampling Period:1s Sampling Frequency:1024Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 314634
-Forward Transformation Execution Time is 314.6340000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 327308
-Inverse Transformation Execution Time is 327.3080000 us (CPU Frequency:1000MHz)
1024 Point FFT Test End
8: 2048 Point FFT Test
-Sampling Period:1s Sampling Frequency:2048Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 619134
-Forward Transformation Execution Time is 619.1340000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 626648
-Inverse Transformation Execution Time is 626.6480000 us (CPU Frequency:1000MHz)
2048 Point FFT Test End
9: 4096 Point FFT Test
-Sampling Period:1s Sampling Frequency:4096Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 1403024
-Forward Transformation Execution Time is 1403.0240000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 1391810
-Inverse Transformation Execution Time is 1391.8100000 us (CPU Frequency:1000MHz)
4096 Point FFT Test End
10: 8192 Point FFT Test
-Sampling Period:1s Sampling Frequency:8192Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 3065058
-Forward Transformation Execution Time is 3065.0580000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 2942344
-Inverse Transformation Execution Time is 2942.3440000 us (CPU Frequency:1000MHz)
8192 Point FFT Test End
11: 16384 Point FFT Test
-Sampling Period:1s Sampling Frequency:16384Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 7421890
-Forward Transformation Execution Time is 7421.8900000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 7359204
-Inverse Transformation Execution Time is 7359.2040000 us (CPU Frequency:1000MHz)
16384 Point FFT Test End
12: 32768 Point FFT Test
-Sampling Period:1s Sampling Frequency:32768Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 16034550
-Forward Transformation Execution Time is 16034.5500000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 15501746
-Inverse Transformation Execution Time is 15501.7460000 us (CPU Frequency:1000MHz)
32768 Point FFT Test End
13: 65536 Point FFT Test
-Sampling Period:1s Sampling Frequency:65536Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 36493010
-Forward Transformation Execution Time is 36493.0100000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 35923952
-Inverse Transformation Execution Time is 35923.9520000 us (CPU Frequency:1000MHz)
65536 Point FFT Test End
14: 131072 Point FFT Test
-Sampling Period:1s Sampling Frequency:131072Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 76507454
-Forward Transformation Execution Time is 76507.4540000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 75288972
-Inverse Transformation Execution Time is 75288.9720000 us (CPU Frequency:1000MHz)
131072 Point FFT Test End
15: 262144 Point FFT Test
-Sampling Period:1s Sampling Frequency:262144Hz Frequency Resolution:1Hz
-Forward Transformation Execution Cycle is 195097318
-Forward Transformation Execution Time is 195097.3180000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 168462636
-Inverse Transformation Execution Time is 168462.6360000 us (CPU Frequency:1000MHz)
262144 Point FFT Test End
--------------------------- Cache Enabled ----------------------------
-Forward Transformation Execution Cycle is 2034
-Forward Transformation Execution Time is 2.0340000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 1638
-Inverse Transformation Execution Time is 1.6380000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 1048
-Forward Transformation Execution Time is 1.0480000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 1257
-Inverse Transformation Execution Time is 1.2570000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 1302
-Forward Transformation Execution Time is 1.3020000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 1513
-Inverse Transformation Execution Time is 1.5130000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 2080
-Forward Transformation Execution Time is 2.0800000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 2812
-Inverse Transformation Execution Time is 2.8120000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 4246
-Forward Transformation Execution Time is 4.2460000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 3828
-Inverse Transformation Execution Time is 3.8280000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 7632
-Forward Transformation Execution Time is 7.6320000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 7307
-Inverse Transformation Execution Time is 7.3070000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 14718
-Forward Transformation Execution Time is 14.7180000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 12958
-Inverse Transformation Execution Time is 12.9580000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 27603
-Forward Transformation Execution Time is 27.6030000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 24465
-Inverse Transformation Execution Time is 24.4650000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 55642
-Forward Transformation Execution Time is 55.6420000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 51792
-Inverse Transformation Execution Time is 51.7920000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 117352
-Forward Transformation Execution Time is 117.3520000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 110913
-Inverse Transformation Execution Time is 110.9130000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 305480
-Forward Transformation Execution Time is 305.4800000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 338549
-Inverse Transformation Execution Time is 338.5490000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 704543
-Forward Transformation Execution Time is 704.5430000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 716023
-Inverse Transformation Execution Time is 716.0230000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 1855574
-Forward Transformation Execution Time is 1855.5740000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 1759068
-Inverse Transformation Execution Time is 1759.0680000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 4640602
-Forward Transformation Execution Time is 4640.6020000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 3878201
-Inverse Transformation Execution Time is 3878.2010000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 48638110
-Forward Transformation Execution Time is 48638.1100000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 14138131
-Inverse Transformation Execution Time is 14138.1310000 us (CPU Frequency:1000MHz)
Test Finished!
回复于 2020-06-30 沙发
回复于 2020-07-02 2#
