首页 论坛 嵌入式软件专区 ARM/单片机 ATSAMA5D27-WLSOM1核心板A5内核:原理图PCB图数据手册资料分享
[资料] ATSAMA5D27-WLSOM1核心板A5内核:原理图PCB图数据手册资料分享
2160 查看
12 回复
 楼主 | 发布于 2019-12-18 | 只看楼主
ATSAMA5D27-WLSOM1资料分享:原理图,PCB,数据手册
资料下载见附件,电脑登入
技术群:124545085
介绍:
        ATSAMA5D27-WLSOM1是基于高性能32位Arm®Cortex®-A5处理器的MPU + 2Gbit LPDDR2系统的小型单端模块化系统(SOM),运行频率可达500MHz,支持WILC3000 WiFi和蓝牙模块以及针对MCP16502电源管理IC优化的电源管理模块。 ATSAMA5D27-WLSOM1建立在一套经过验证的通用Microchip组件上,通过简化硬件设计和软件开发来缩短产品上市时间。它还简化了主应用板的设计规则,从而降低了整体PCB的复杂性和成本。 ATSAMA5D27-WLSOM1随附了免费的Linux发行版和裸机C代码示例。
基础特征:
  • Arm® Cortex®-A5 processor-based SAMA5D2 MPU
  • 256 MByte LPDDR2 SDRAM
  • MCP16502 Power Management IC
  • WILC3000 WiFi and Bluetooth module
  • 64Mb Serial Quad I/O Flash Memory with Embedded EUI-48 MAC addresses
  • KSZ8081 10Base-T/100Base-TX Ethernet PHY
  • Pre-provisioned ECC608 Secure Element (Trust&Go)
  • 40.8 x 40.8 mm Module, Pitch 0.8mm, Solderable Manually for Prototyping
参数:
Parametrics
Name        Value
Part Family                                                              SAMA5D2
Core        Cortex-A5
FPU        Yes
ARM Neon        Yes
Arm Trust Zone®                                                      Yes
Max CPU Speed (MHz)                                              500
Core Voltage Range (V)                                             3 to 5.5
Vbat/Vddbu battery backup                                      Yes
Internal Oscillator                                                       32kHz, 24MHz and 25MHz
SRAM (KB)        128
L1 Cache Memory (Instructions) (KB)                         32
L1 Cache Memory (Data) (KB)                                     32
L2 Cache Memory (KB)                                                128
DRAM Interface                                                           LPDDR2
DRAM Bus Size (Bits)                                                   32
Internal DRAM Type                                                    LPDDR2
Internal DRAM Amount (MB)                                      256
NAND Interface                                                           Yes
ECC Bits on NAND Interface                                        32
Number of EBIs                                                            1
SDIO/SD-CARD/eMMC                                                1
QSPI        2
Direct Memory Access Channels                                  51
Max I/O Pins        94
Pincount        188
UART        5
ISO 7816        5
SPI        2
I2C        1
SSC        1
CAN        2
Type of CAN Module                                                  CAN
LIN        Yes
USB Device Only Ports                                                 1 HS
USB Device and Host Ports                                          1 HS
USB Host Only Ports                                                    1 HS
10/100 Ethernet MAC                                                  1
Ethernet PTP & AVB Support                                       Ethernet PTP
Graphics Controller/GPU                                              Yes
Graphic LCD        18-bit
Camera Interface                                                           Yes
Integrity Check Monitor (ICM)                                      Yes
Secure Bootloader                                                         Yes
Crypto Engine        Yes
External Memory Encrypt/Decrypt                                Yes
Anti-Tamper Pins                                                           7
Secure Key Storage (Fuse bits)                                      544
ADC Input        6
Max ADC Resolution (bits)                                            12
Max ADC Sampling Rate (ksps)                                     1000
Temp Sensor        Yes
Hardware RTCC/RTC                                                      Yes
Watch Dog Timer                                                           Yes
Max 16-Bit Digital Timers                                              4
Max 32-Bit Digital Timers                                              5
Input Capture        5
Standalone Output Compare/Standard PWM              5
Quadrature Encoder Interface                                       2
Temperature Range (C)                                                -40 to 85
(1 ) (1 )
arm 嵌入式Linux 嵌入式开发
回复于 2019-12-18 沙发
不错,感谢分享
回复于 2019-12-18 2#
回复于 2019-12-18 3#
回复于 2019-12-19 4#
回复于 2019-12-21 5#
回复于 2019-12-24 6#
学习了!感谢分享!
回复于 2019-12-28 7#
感谢分享!!!!
回复于 2019-12-28 8#
感谢分享!!!!
回复于 2020-02-23 9#
回复于 2020-02-23 10#
