- 普通用户_31d2ae73c71a46e
21 发帖0 回复205 积分
- 私信他 + 关注
In the field of wireless communications, IPQ4019/IPQ4029-DR40X9 stands out with its excellent performance and price advantages. This series of products uses industrial-grade IPQ4019/IPQ4029 chipsets and integrates 2x2 5G high-power RF modules and 2x2 2.4G high-power RF modules, giving it excellent flexibility in frequency range, bandwidth and connection options.
main feature:
Excellent performance: The IPQ4019/IPQ4029 chipset is equipped with a quad-core ARM Cortex A7 processor with a main frequency of 716.8MHz, ensuring the stable operation of the device under high load. Supports 11ABGN/AC and multiple frequency ranges to meet the needs of different application scenarios.
Flexible frequency range: This series of products supports the frequency range from 4.940GHz to 5.825GHz, and the frequency range from 2.400GHz to 2.482GHz, ensuring that devices can achieve efficient communication in different frequency bands.
Multiple connection options: Equipped with 2 5G MMCX connectors and 2 2.4G MMCX connectors, users can choose different antenna combinations as needed to improve signal coverage and transmission performance.
Rich bandwidth support: Supports 5MHz/10MHz/20MHz/40MHz/80MHz bandwidth to ensure that the device can flexibly adapt to different network environments and achieve higher data transmission rates.
Comprehensive firmware support: The product firmware is compatible with all Quectel modules and supports open source platforms such as Openwifi, QSDK and Openwrt, providing users with greater customization space and flexibility.
Industrial-grade standards: Comply with RoHS environmental protection requirements to ensure the protection of human health and the environment during use of the equipment.
Long-Distance Transmission:
23km Coverage Range: Demonstrating exceptional long-distance transmission capabilities, the DR40X9 covers distances up to 23 kilometers, suitable for various long-range communication needs.
Hardware specifications:
CPU: IPQ4029 (Quad-core ARM Cortex A7, 716.8 MHz)
Antenna connector: 2 5G MMCX connectors; 2 2.4G MMCX connectors
10/100/1000Mbps Gigabit Ethernet: 2 RJ45
SFP connector: 1xSFP fiber optic module connector (optional)
3G/4G connector: 1xminipcie 3G/4G connector, supports two SIM cards
USB connector: 1xUSB 3.0 connector
POE: 24V~48V passive POE
DC jack: 24V~48V power supply
ROHS Compliance: Yes
Dimensions: 115mm x 105mm x 16mm
Maximum power: 48.1V×0.180A=8.658W
Flash memory: 2MB~32MB
Storage: 128MB
DDR: 256MB~512MB
Radio transmit and receive specifications:
Radio transmission specifications (5180MHz-5825MHz)
Radio reception specifications (5180MHz-5825MHz)
Radio transmission specifications (2412MHz-2482MHz)
Radio reception specifications (2412MHz-2482MHz)
Absolute Maximum Ratings:
Power supply voltage: 24V~48V
Operating temperature range: -40 to +70 ℃
Storage temperature range: -45 to +105 ℃
Operating humidity range: 5 to +95 (non-condensing) %
Storage humidity range: 0 to +90 (non-condensing) %
TheIPQ4019/IPQ4029-DR40X9 series products have become a star choice in the field of wireless communications due to their excellent performance, flexible configuration and design that meets industrial standards. Whether used in enterprise networks, IoT devices or other wireless communication applications, this series of products can meet users' needs for high quality, reliability and flexibility.
嵌入式Linux 嵌入式处理器 PCB布局 DSP处理器 DSP设计
