- 普通用户_31d2ae73c71a46e
21 发帖0 回复205 积分
- 私信他 + 关注
In the dynamic landscape of wireless technology, innovation is the key to staying ahead. Today, we're thrilled to introduce the DR6018-S, featuring the powerful Qualcomm-Atheros IPQ6018 processor. This groundbreaking device is designed to elevate your wireless experience with cutting-edge features and unparalleled performance.
Key Features:
Quad-core ARM 64bit A53 @1.8GHz Processor:
The heart of DR6018-S boasts a robust Quad-core ARM 64-bit A53 processor clocked at 1.8GHz. This powerful CPU ensures seamless multitasking, efficient data processing, and enhanced overall performance.
1GB DDR3L System Memory:
Equipped with 1GB DDR3L system memory, the DR6018-S delivers high-speed data access and smooth operation, making it ideal for various applications, from home networking to industrial deployments.
Dual-Band Radios:
DR6018-S features 2x2 on-board radios for both 2.4GHz and 5GHz bands. With a physical data rate of up to 573Mbps on the 2.4GHz band and 1201Mbps on the 5GHz band, this device ensures a fast and reliable wireless connection for a wide range of devices.
Openwifi Support:
Embrace the freedom to customize your wireless experience with Openwifi support. The DR6018-S gives you the flexibility to tailor your network settings to suit your unique requirements.
Dynamic Frequency Selection (DFS):
Stay ahead of regulatory requirements with DFS support, allowing the device to dynamically select frequencies and optimize performance while adhering to regional regulations.
Robust Flash Storage:
The DR6018-S comes with 8MB NOR Flash and 256MB NAND Flash, providing ample storage for firmware and data, ensuring reliability and stability in operation.
Compact Design:
With dimensions of 125mm x 105mm x 20mm, the DR6018-S offers a compact form factor without compromising on performance. This makes it suitable for a variety of applications where space is a consideration.
Versatile Connectivity Options:
The device supports various connectivity options, including Ethernet ports, M.2 (NGFF) socket for WiFi modules, SD card slot, USB 3.0 port, and serial port. It also offers Power over Ethernet (POE) options for added convenience.
Key Features:
Dual-Band Radios:
Openwifi Support:
Compact Design:
(0 )
(0 )
嵌入式Linux PCB布局 PCB加工 DSP处理器 DSP芯片
