[分享] STSW-S2LP-SFX-DK
681 查看
 楼主 | 发布于 2018-12-15 | 只看楼主
•Enhanced use of NVM. Now Flash memory can be used to store/retrieve credentials and Sigfox data
•Encryption tool to generate bin file for flash Sigfox credentials
•Support for X-NUCLEO-S2868A1
•Support for BlueNRG-1 and BlueNRG-2
•Command Line Interface (CLI)
◦Integrated start/stop Continous Modulation
◦Added new commands for set both frequency and RSSI offset and payload encryption
◦Added the node_send_bit command
◦Added the switch_test_credentials command in order to use test_credentials on registered boards
◦Added the node_open_with_zone command that allows to select RC Zone before open the library
•Added CLI in source code as new project sample
Correcionts/Changes
•Project libraries now integrate Sigfox Lib v2.5.0 as well as Sigfox ADDON v0.4.0.
•Command Line Interface (CLI) - Fixed version number bug
•Not registered board now automatically set ID and KEY for test
•Bugfixes
◦Fixed possible hangs during RX SENSI test
◦Fixed error with payload encryption
◦Fixed issue with HMAC encryption when using public key
回复于 2018-12-15 沙发
回复于 2018-12-15 2#
回复于 2018-12-24 3#
回复于 2019-02-10 4#
