首页 论坛 创客及开源专区 开源、DIY及3D打印 分享个国外开源:便携式全屏触摸DDS 波形发生器原理图和PCB源文件等资料大分享
[资料] 分享个国外开源:便携式全屏触摸DDS 波形发生器原理图和PCB源文件等资料大分享
3628 查看
35 回复
 楼主 | 发布于 2018-12-13 | 只看楼主
资料下载见附件:电脑登入
出处:国外
 图纸打开:Cadence Allegro
技术群:124545085
some components:
- An AD9834 (DDS chip with sinus/triangle output)
- 2 x AD5310 (10bit DAC: one for the Vpp control, another one the offset control)
- 3 x LM7171 (Fast OPA)
- 3 x LT1616 (switching regulator: +5V, +7V, -7V)
This waveform generator is directly powered by a standard 12V jack and is capable of outputting a 10Vpp signal at 1MHz (between -5V and +5V, sinus waveform, no load). Above 1MHz, the output starts fading, reaching only 9Vpp at 4MHz (maximal frequency). Frequency, amplitude and offset are digitally controlled through the smart TFT.
Three “basic” waveforms are provided: sinus and triangle, coming from the DDS chip (0.1Hz to 4MHz, 0.1Hz step), and PWM coming from the microcontroller (0.1Hz to 1MHz, variable steps).
The microcontroller also provides arbitrary waveforms such as sawtooth, sin(x)/x, noise, wav file playback, etc… but at lower frequencies (0 to 2kHz -- or 100kSPS). Each waveform can be directly outputted, or can be used as an input for frequency or amplitude modulation.
(2 ) (2 )
回复于 2018-12-15 11#
谢谢分享。。。厉害///
回复于 2018-12-15 12#
回复于 2018-12-15 13#
回复于 2018-12-24 14#
只有我打不开这张原理图么?
回复于 2018-12-24 15#
回复于 2019-01-17 16#
回复于 2019-01-24 17#
回复于 2019-02-23 18#
回复于 2019-04-20 19#
感谢分享;
回复于 2019-04-21 20#
