[分享] 可穿戴无线多参数患者监护仪参考设计
654 查看
9 回复
 楼主 | 发布于 2018-09-07 | 只看楼主
This reference design is a simple, wearable, multi-parameter, patient monitor that uses a single-chip, biosensing front end, the AFE4900 device, for synchronized electrocardiography (ECG) and photoplethysmography (PPG) measurements. The measured data is transferred to a remote location using the CC2640R2F device (supporting BLE 4.2 and 5). The reference design is operated using a single CR3032 battery and provides a battery life of 30 days. The raw data is available for the user to calculate heart-rate, oxygen concentration in blood (SpO2), pulse-transit time (PTT), and ECG. Two onboard light-emitting diodes (LEDs) indicate low-battery detection and ECG lead-off detection for users.
楼主 | 回复于 2018-09-07 沙发
  • Simple, wearable, multi-parameter, patient monitor for PPG and ECG
  • Provides raw data to calculate heart rate, SpO2, and PTT
  • Uses single-chip, biosensing front-end AFE4900 device for synchronized ECG and PPG measurements
    • PPG (Optical heart-rate monitoring and SpO2) supports four LEDs and three photodiodes (PDs), with digital ambient subtraction to improve signal-to-noise ratio (SNR)
    • ECG (LEAD I) signals
  • Integrated Arm® Cortex®-M3 and 2.4-GHz RF transceiver (CC2640R2F) supports wireless data transfer - BLE 4.2 and 5.0
  • Operated by CR3032 (3-V, 500-mA coin-cell battery), with battery life of 30 days using highly efficient DC/DC converters
  • Small form factor helps with easy adaptation to wearable applications
楼主 | 回复于 2018-09-07 2#
楼主 | 回复于 2018-09-07 3#
回复于 2018-09-10 4#
回复于 2018-09-10 5#
回复于 2018-09-10 6#
回复于 2018-09-12 7#
支持下,谢谢分享
回复于 2018-09-15 8#
支持下,谢谢分享
回复于 2018-10-19 9#
感谢分享,有需要机器人方案的可联系我,相互学习,共同进步
