首页 论坛 原厂专区 TI MCU MSP430x14x模糊逻辑马达控制-源程序,已通过测试
[资料] MSP430x14x模糊逻辑马达控制-源程序,已通过测试
557 查看
 楼主 | 发布于 2018-08-29 | 只看楼主
#include "msp430x14x.h"
#define PWM_Period      3999                    // 8MHz / 4000 = 2kHz
#define PWM_Max         1199                    // Max duty factor used
#define PWM_Min         149                     // Min duty factor used
#define MIN_SPEED       10000                   // Min. measured speed
int Array[700];                                 // Debug buffer
int pArray = 0;
unsigned int SetSpeed = 1667;                   // 1667 equal 50rpsec
                                                // SetSpeed = f_Timer / (RevPerSec * 24)
                                                // with f_Timer = 2MHz
unsigned int LastTACCR;                         // Speed measurement vars
unsigned int CurrentSpeed = MIN_SPEED;
unsigned long SpeedMemSum = 8 * (unsigned long)MIN_SPEED;
unsigned int pSpeedMem = 0;
unsigned int SpeedMem[8] =
  MIN_SPEED, MIN_SPEED, MIN_SPEED, MIN_SPEED,
long Error;                                     // Control algorithm vars
long dError;
long LastError;
long PWMValue;
int X1[5];                                      // Fuzzy control variables
int X2[5];
int Y[5];
int Output;
#define NM          0                           // negative medium
#define NS          1                           // negative small
#define ZE          2                           // zero equal
#define PS          3                           // positive small
#define PM          4                           // positive medium
const unsigned char InferenceTable[5][5] =
  { PM, PM, PM, PS, ZE },
  { PM, PM, PS, ZE, NS },
  { PM, PS, ZE, NS, NM },
  { PS, ZE, NS, NM, NM },
  { ZE, NS, NM, NM, NM }
const signed char OutputFunc[5] =
  -0x10, -0x08, 0, 0x08, 0x10
// Function prototypes
void InitSystem(void);
void Fuzzification(int Value, int *Data);
void FuzzyInference(int *Error, int *dError, int *Y);
int Defuzzification(int *Y);
__interrupt void WDT_ISR(void);
__interrupt void TimerA0_ISR(void);
__interrupt void TimerA1_ISR(void);
void main(void)
  volatile unsigned int i;
  InitSystem();
  while (1)
    __bis_SR_register(LPM0_bits);               // Enter LPM, wait for start of
                                                // next control cycle
    // If Error > 0 then motor is to fast
    // If Error < 0 then motor is to slow
    LastError = Error;
    __disable_interrupt();                      // Protect following statements
    Error = (long)SetSpeed - CurrentSpeed;      // Calc absolute error
    if (pArray < sizeof Array/sizeof Array[0])  // Store some values for debug
      Array[pArray++] = CurrentSpeed;
    __enable_interrupt();
    Error <<= 3;                                // Multiply by 8
    dError = Error - LastError;                 // Calc differential error
    dError <<= 5;                               // Multiply by 32
    // Ensure error is within Fuzzy boundaries
    if (Error > 0xc00)                          // Motor too fast?
      TBCCR2 = PWM_Min;                         // Set PWM to minimum
      continue;                                 // Skip over control algorithm
    if (Error < -0xc00)                         // Motor too slow?
      TBCCR2 = PWM_Max;                         // Set PWM to maximum
    Fuzzification(Error, X1);                   // Transform absolute error
    Fuzzification(dError, X2);                  // Transform differential error
    FuzzyInference(X1, X2, Y);                  // Apply Fuzzy rule table
    Output = Defuzzification(Y);                // Obtain scalar result
    PWMValue = TBCCR2 + Output;
    if (PWMValue < PWM_Min) PWMValue = PWM_Min; // Limit output value
    if (PWMValue > PWM_Max) PWMValue = PWM_Max;
    TBCCR2 = PWMValue;                          // Assign new PWM duty cycle
// Function converts the discrete input value 'Value' into the 5-element
// Fuzzy vector Data[].
  int i;
  for (i = 0; i < 5; i++)
    Data[i] = 0;
  if (Value < -0x800)
    Data[NM] = 0x400;
  else if (Value < -0x400)
    Data[NM] = 0x400 - (Value + 0x800);
    Data[NS] = Value + 0x800;
  else if (Value < 0)
    Data[NS] = 0x400 - (Value + 0x400);
    Data[ZE] = Value + 0x400;
  else if (Value < 0x400)
    Data[ZE] = 0x400 - Value;
    Data[PS] = Value;
  else if (Value < 0x800)
    Data[PS] = 0x400 - (Value - 0x400);
    Data[PM] = Value - 0x400;
  else
    Data[PM] = 0x400;
// Function applies the Fuzzy control interference rule table InferenceTable[][]
// to the two input arrays X1[] and X2[] to generate the output vector Y[].
void FuzzyInference(int *X1, int *X2, int *Y)
  int min[5];
  int max;
  int maxpos;
  int i, j;
  for (i = 0; i < 5; i++)                       // Clear output vector Y[]
    Y[i] = 0;
  for (i = 0; i < 5; i++)                       // Loop through X1[]
    for (j = 0; j < 5; j++)                     // Loop through X2[]
      if (X1[i] < X2[j])                        // Determine smaller value,
        min[j] = X1[i];                         // store into min[]
      else
        min[j] = X2[j];
    max = min[0];                               // Find maximum in min[]
    maxpos = 0;
    for (j = 1; j < 5; j++)
      if (max < min[j])
        max = min[j];                           // Store maximum
        maxpos = j;                             // Store position of maximum
    if (max > Y[InferenceTable[i][maxpos]])     // Apply inference table
      Y[InferenceTable[i][maxpos]] += max;
    if (Y[InferenceTable[i][maxpos]] > 0x400)   // Limit output vector elements
      Y[InferenceTable[i][maxpos]] = 0x400;
楼主 | 回复于 2018-08-29 沙发
// Function transforms the Fuzzy vector Y[] to a discrete value using the
// center of gravity method.
  int i;
  int ReturnVal = 0;
  int SumY = 0;
    SumY += Y[i];
    ReturnVal += Y[i] * OutputFunc[i];
  return ((long)ReturnVal << 2) / SumY;         // Scale result by 4
// MSP430-specific initialization of clock system and timer modules
  WDTCTL = WDTPW + WDTHOLD;                     // Hold WDT
  // Setup Clock System
  BCSCTL1 |= XTS;                               // ACLK=LFXT1=HF XTAL
  do {
    IFG1 &= ~OFIFG;                             // Clear OSCFault flag
    for (i = 0xFF; i > 0; i--);                 // Time for flag to set
  } while (IFG1 & OFIFG);                       // OSCFault flag still set?
  BCSCTL2 |= SELM_3;                            // MCLK=LFXT1 (safe)
  // Setup Ports
  P2SEL = 0x04;                                 // Assign P2.2 to Timer_A.CCI0B
  P4SEL = 0x04;                                 // Assign P4.2 to Timer_B.OUT2
  P4DIR = 0x04;                                 // P4.2 output
  // Setup Timer_A for speed measurement
  TACCR1 = MIN_SPEED;                           // Set minimum speed that is read out
  TACCTL0 = CM_1 + CCIS_1 + SCS + CAP + CCIE;   // Capture rising edge of CCI0B, interrupt
  TACCTL1 = CCIE;                               // Compare mode, interrupt on EQU1
  TACTL = TASSEL_1 + ID_2 + MC_2;               // Use ACLK/4=2MHz, start in continuos mode
  // Setup Timer_B for PWM generation
  TBCCR0 = PWM_Period;                          // PWM Period
  TBCCTL2 = OUTMOD_7 + CLLD0;                   // Set OUT2 on EQU0, reset on EQU1,
                                                // sync latch load with EQU0
  TBCTL = TBSSEL_1 + MC_1;                      // Use ACLK, start in up-mode
  // Setup WDT for periodic interrupt
  WDTCTL = WDTPW + WDTTMSEL + WDTSSEL;          // Intervall timer, 8MHz/32768=244Hz
  IE1 |= WDTIE;
楼主 | 回复于 2018-08-29 2#
// The Watchdog-timer ISR is used to periodically wake-up from low-power mode
// LPM0 to execute the Fuzzy control loop.
#pragma vector = WDT_VECTOR
  __bic_SR_register_on_exit(LPM0_bits);         // Wake up from LPM
// The Timer_A CCR0 ISR is called on each TACCR0 capture event to obtain
// the time stamp of the input signal transition. An 8-tap moving average
// filter is used to minimize measurement error.
#pragma vector = TIMERA0_VECTOR
  SpeedMemSum -= SpeedMem[pSpeedMem];           // Remove oldest value
  SpeedMem[pSpeedMem] = (unsigned int)(TACCR0 - LastTACCR);  // Replace with current
  SpeedMemSum += SpeedMem[pSpeedMem++];         // Update running sum
  CurrentSpeed = SpeedMemSum >> 3;              // Calc speed by div 8
  pSpeedMem &= 0x07;                            // Adjust circular pointer
  LastTACCR = TACCR0;
  TACCR1 = LastTACCR + MIN_SPEED;               // Set timeout for minimum speed
}                                               // to be read out
// The Timer_A CCR1 ISR is called on TACCR1 compare events, which are generated
// when no input signal change is detected within 'MIN_SPEED' clock ticks after
// the last TACCR0 event. This provides a timeout function to update the speed
// variables in the case the motor gets halted.
#pragma vector = TIMERA1_VECTOR
  switch (TAIV)
    case 0x02 :                                 // TACCR1 CCIFG
      SpeedMem[pSpeedMem] = (unsigned int)(TACCR1 - LastTACCR);  // Replace with current
      LastTACCR = TACCR1;
      break;                                    // to be read out
楼主 | 回复于 2018-08-29 3#
所有代码是一个c文件,因为发帖字数限制分成了三个楼层
回复于 2018-08-30 4#
谢谢分享!!!!!!!!!!!
回复于 2018-08-30 5#
楼主 | 回复于 2018-08-30 6#
楼主 | 回复于 2018-08-30 7#
一起分享
