[资料] MSP430x14x读写FM25L256程序
627 查看
 楼主 | 发布于 2018-08-28 | 只看楼主
#include "msp430x14x.h"
#define SET_FE_CS_DIR		P3DIR|=BIT0
#define SET_FE_CLK_DIR		P3DIR|=BIT3
#define SET_FE_IN_DIR		P3DIR|=BIT2
#define SET_FE_OUT_DIR		P3DIR|=BIT1
#define CLR_FE_CS_DIR		P3DIR&=~BIT0
#define CLR_FE_CLK_DIR		P3DIR&=~BIT3
#define CLR_FE_IN_DIR		P3DIR&=~BIT2
#define CLR_FE_OUT_DIR		P3DIR&=~BIT1
#define SET_FE_CS 		P3OUT|=BIT0
#define SET_FE_CLK		P3OUT|=BIT3
#define SET_FE_IN		P3OUT|=BIT2
#define SET_FE_OUT		P3OUT|=BIT1
#define CLR_FE_CS 		P3OUT&=~BIT0
#define CLR_FE_CLK		P3OUT&=~BIT3
#define CLR_FE_IN		P3OUT&=~BIT2
#define CLR_FE_OUT		P3OUT&=~BIT1
#define FE_WREN			0X06
#define FE_WRDI			0X04
#define FE_WRSR			0X01
#define FE_RDSR			0X05
#define FE_READ			0X03
#define FE_WRITE		0X02
#define READ_FE_IN    		((P3IN>>2)&0X01)
void FE_SET(void);
void FE_START(void);
void FE_END(void);
void FE_WREN1(void);
void FE_WRDI1(void);
void FE_OUT(unsigned char wData);
void FE_Writebyte1(unsigned int adr,unsigned char wByte);
void FE_WriteBlock(unsigned int adr,unsigned char *WriteData,unsigned int count);
void FE_ReadBlock(unsigned int adr,unsigned char *ReadData,unsigned int count);
unsigned char FE_IN(void);
unsigned char FE_Readbyte1(unsigned int adr,unsigned char rByte);
void FE_SET(void)
 SET_FE_CS_DIR;
 SET_FE_CLK_DIR;
 CLR_FE_IN_DIR;
 SET_FE_OUT_DIR;
void FE_START(void)
 SET_FE_CS;
 CLR_FE_CLK;
 CLR_FE_CS;
void FE_END(void)
 CLR_FE_CLK;
 SET_FE_CS;
void FE_WREN1(void)
 FE_START();
 FE_OUT(FE_WREN);
 FE_END();
void FE_WRDI1(void)
 FE_START();
 FE_OUT(FE_WRDI);
 FE_END();
 unsigned char i;
 unsigned char TempBit  = 0;
 unsigned char TempData = 0;
 CLR_FE_IN_DIR;
 for(i=0;i<8;i++)
  SET_FE_CLK;
  if (READ_FE_IN == 0x01 /*sda==1*/)
      TempBit = 1;
  else
      TempBit = 0;
  TempData = (TempData << 1) | TempBit;
  CLR_FE_CLK;
  _NOP();
  _NOP();
  return(TempData);
void FE_OUT(unsigned char WriteData)
 unsigned char i;
 SET_FE_OUT_DIR;
 for(i=0;i<8;i++)
// SET_FE_CLK;
  if (((WriteData >> 7) & 0x01) == 0x01)
      SET_FE_OUT;
      SET_FE_CLK;
      CLR_FE_CLK;
      _NOP();
      _NOP();
    else
      CLR_FE_OUT;
      SET_FE_CLK;
      CLR_FE_CLK;
      _NOP();
      _NOP();
    WriteData = WriteData << 1;
void FE_Protect(void)
 FE_WREN();
 FE_START();
 FE_OUT(FE_WRSR);
 FE_OUT(0X01);
 FE_END();
void FE_UNProtect(void)
 FE_WREN();
 FE_Start();
 FE_OUT(FE_WRSR);
 FE_OUT(0X02);
 FE_END();
 unsigned char temp;
 //FE_UNProtect();
 FE_WREN1();
 FE_START();
 FE_OUT(FE_WRITE);
 temp=(unsigned char)(adr>>8);
 FE_OUT(temp);
 FE_OUT((unsigned char)(adr));
 FE_OUT(wByte);
 FE_END();
 //FE_Protect();
 unsigned char temp;
 FE_WREN1();
 FE_START();
 FE_OUT(FE_READ);
 FE_OUT(temp);
 rByte=FE_IN();
 FE_END();
 return rByte;
 unsigned int i;
 //FE_UNProtect();
 FE_WREN1();
 FE_START();
 FE_OUT(FE_WRITE);
 FE_OUT(temp);
 for(i=0;i<count;i++)
  FE_OUT(WriteData[i]);
 FE_END();
 //FE_Protect();
 unsigned int i;
 FE_WREN1();
 FE_START();
 FE_OUT(FE_READ);
 FE_OUT(temp);
  ReadData[i]=FE_IN();
 FE_END();
void main(void)
 unsigned char t,i;
 unsigned int  tt;
 float b=0.0;
 WDTCTL=WDTPW+WDTHOLD;
 //select clk
 BCSCTL1=0;
 BCSCTL2=0X88;//SELM.1+SELS
 do
  IFG1&=~OFIFG;
  for(i=0xff;i>0;i++);
 while((IFG1&OFIFG)!=0);
 //_EINT();
 P2DIR|=BIT7;
 P2OUT|=BIT7;
 FE_SET();
 tt=0x3FFF;
 t=0x80;
 FE_Writebyte1(tt,t);
 b=FE_Readbyte1(0x3FFF,t);
// tt=t;
 while(1)
回复于 2018-08-29 沙发
感谢分享;
回复于 2018-08-30 2#
谢谢分享!!!!!!!!!!!
楼主 | 回复于 2018-08-30 3#
感谢支持
楼主 | 回复于 2018-08-30 4#
一起分享
回复于 2018-09-15 5#
支持下,谢谢分享
