[资料] BMF055(9轴+ CortexM0+) and BSX Lite(融合算法)
2879 查看
23 回复
 楼主 | 发布于 2018-01-08 | 只看楼主
BMF055在一个5.2 x 3.8 x 1.1 mm³封装里包含了3轴加速计,3轴陀螺仪,3轴地磁 和一个CortexM0+的MCU
而且硬件开源,允许用户重新编程,十分方便外部扩展。
有利于项目初期软件硬件开发和算法验证,加快产品面世
软件的源代码可以从Atmel网站获得
The BMF055 is an extension of the Application Specific Sensor Nodes (ASSN) family implementing a custom programmable 9-axis motion sensor which includes sensors and a microcontroller in a single package.
The BMF055 is a System in Package (SiP), integrating a triaxial 14-bit accelerometer, a triaxial 16 bit gyroscope with a range of ± 2000 degrees per second, a triaxial geomagnetic sensor and a 32 bit Cortex M0+ microcontroller from Atmel. At just 5.2 x 3.8 x 1.1 mm³, it is significantly smaller than comparable discrete or system on board solutions.
Applications
- Augmented reality
- Navigation
- Gaming
- Robotics
- Industrial applications
回复于 2018-01-10 沙发
666666666666666
回复于 2018-01-12 2#
感谢分享;
回复于 2018-01-13 3#
看看看
回复于 2018-01-25 4#
回复于 2018-02-09 5#
下来看看
回复于 2018-03-08 6#
回复于 2018-05-28 7#
回复于 2018-06-01 8#
支持一下
回复于 2018-06-09 9#
看看
回复于 2018-08-10 10#
谢谢楼主分享
