[资料] STSPIN32F0601/0602:600V BLDC驱动(内置MCU)
1520 查看
9 回复
 楼主 | 发布于 2019-10-14 | 只看楼主
STSPIN32F0601/0602:600V BLDC驱动(内置MCU/比较器过流保护/MOS或IGBT驱动等)
资料下载见附件,电脑登入
The STSPIN32F060x system-in-package is an extremely integrated solution for driving three-phase applications, helping designers to reduce PCB area and overall bill-of-material.
It embeds an STM32F031x6x7 featuring an ARM® 32-bit Cortex®-M0 CPU and a 600 V triple half-bridge gate driver, able to drive N-channel power MOSFETs or IGBTs.
A comparator featuring advanced smartSD function is integrated, ensuring fast and effective protection against overload and overcurrent.
The high-voltage bootstrap diodes are also integrated, as well as anti cross-conduction, deadtime and UVLO protection on both the lower and upper driving sections, which prevents the power switches from operating in low efficiency or dangerous conditions. Matched delays between low and high-side sections guarantee no cycle distortion.
The integrated MCU allows performing FOC, 6-step sensorless and other advanced driving algorithms including the speed control loop.
主要特性
  • Three-phase gate drivers
    • High voltage rail up to 600 V
    • Driver current capability:STSPIN32F0601: 200/350 mA source/sink currentSTSPIN32F0602:1/0.85 A source/sink current
    • dV/dt transient immunity ±50 V/ns
    • Gate driving voltage range from 9V to 20V
  • 32-bit ARM® Cortex®-M0 core:
    • Up to 48 MHz clock frequency
    • 4-Kbyte SRAM with HW parity
    • 32-Kbyte Flash memory with option bytes used for write/readout protection
  • 21 general-purpose I/O ports (GPIO)
  • 6 general-purpose timers
  • 12-bit ADC converter (up to 10 channels)
  • I2C, USART and SPI interfaces
  • Matched propagation delay for all channels
  • Integrated bootstrap diodes
  • Comparator for fast over current protection
  • UVLO, Interlocking and deadtime functions
  • Smart shutdown (smartSD) function
  • Standby mode for low power consumption
  • On-chip debug suppor
楼主 | 回复于 2019-10-14 沙发
回复于 2019-10-15 2#
回复于 2019-10-16 3#
回复于 2019-10-17 4#
感谢分享!!!
回复于 2019-10-21 5#
回复于 2020-03-05 6#
回复于 2020-03-09 7#
回复于 2020-03-09 8#
谢谢资源.
回复于 2020-03-13 9#
