[讨论] DR7915-wifi6-MT7915-MT7975-2T2R-support-
194 查看
 楼主 | 发布于 2022-08-24 | 只看楼主
DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-802.11AX-supporting-MiniPCIe-Module
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IQCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344 /AX200NGW
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
In the complex market, Wallys products stand out and are affirmed by partners. From 802.11 a - ax, Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:sales3@wallystech.com
DR7915
https://www.wallystech.com/Network_Card/DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-802.11AX-supporting-MiniPCIe-Module.html
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
CardsareindividuallycalibratedforQualityAssurance
https://www.youtube.com/watch?v=yUoTXPFjNmk
    Product Description
    DR 7915 based on MT7915 + MT7975 Chipset is an enterprise wireless module integrated with 2x2 2.4G high power Radio module and 2x2 5G high power Radio module designed
    specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment infactories, warehousese stablishment.
       Specifications
    Symbol
    Parameter
    Chipset
    MT7915+MT7975
    Host Interface
    Mini PCI Express 2.1
    Antenna Connector
    2 x UF.L
    Frequency Range
    2.4GHz: 2.412GHz to 2.472GHz
    5GHz: 5.180GHz to 5.825GHz
    Operating Voltage
    3.3V DC
    Power Consumption
    TBD
    Modulation Techniques
    OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
    Environmental Temperature
    Operating: -40°C to 70°C, Storage: -40°C to 90°C
    Environmental Humidity, non-condensing
    Operating: 5% to 95%, Storage: Max. 90%
    ROHS Compliance
    YES
    Dimensions (W×H×D)
    51mm × 30mm × 5.8mm
