[资料] qca9882 waliys 2×2 MIMO 802.11ac Mini
159 查看
 楼主 | 发布于 2022-08-23 | 只看楼主
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IQCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344 /AX200NGW
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
In the complex market, Wallys products stand out and are affirmed by partners. From 802.11 a - ax, Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:sales3@wallystech.com
DR600VX
https://www.wallystech.com/Network_Card/DR600VX-Qualcomm-Atheros-QCA9880-2T2R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-Dual-Band-2.4GHz-5GHz.html
http://https://www.youtube.com/watch?v=P6bf0KrO5e8
PRODUCT DESCRIPTION
dr600VX ProPlus based on QCA9880 chipset is an enterprise wireless module integrated with 2×2 5G high power Radio module and 2×2 2.4G high power Radio module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses establishment. Designed for higher volume of clients & loads. CE RED, IC and FCC certified and full test reports available! FCC 4,9GHZ Certified for US market!
PROPlus
  • Improved QCA XB140 Reference design for QCA 9880 chipset
  • Changed the FEM, power – lower real and extended working temperature range
  • Improved RF circuits – Higher Tx Power, better RX sensitivity
  • Improved & better layout for higher performance
  • See comparison protocol ProPlus vs Standard module for details (download here)
  • Designed for heavy data loads & higher amount of clients
  • Cases studies available ! Approved for WiFi for passangers & Railroads
FEATURES
  • 2.4GHz max 24dBm & 5GHz max 23dBm output power
  • IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
  • 2×2 MIMO Technology, up to 867Mbps
  • Mini PCI Express edge connector
  • RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
  • Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC), Support the Frequency 4920MHz~4980MHz for US region.
  • Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
  • Supports Dynamic Frequency Selection (DFS)
  • Cards are individually calibrated for Quality Assurance
  • Designed for higher numbers of clients connections & support for extreme loads
  • Linux drivers support – Ath10k, Candela wireless drivers, based on QCA reference design
  • Certifications : CE RED, FCC, IC Canada
  • Qualcomm-Atheros QCA9880 chipset
APPLICATIONS
  • Profi WiFi hotspot coverage
  • Commercial radio coverage
  • Hotel Wireless application
  • Country coverage
  • Internet for passengers (bus, train, plane, …)
  • Security Surveillance
  • Some special scene application
  • Heavy-duty industrial environment use
FOR MORE PROTOCOLS AND DETAILS CHECK
http://wifi5.eu/dls/524wifi/524wifi600vxProPlus/
Latest changes to improve possible. All right reserved by their respective owners. Designed by and manufactured for Tomorrow systems s.r.o. .
524WiFi 600VX (and 900VX ) based on QCA9880 chipset – 524WiFi version has better power amplifier, higher sensitivity a higher tx power (check data) . Enterprise wireless modules integrated with 3×3 5G high power Radio module and 3×3 (resp 2×2) 2.4G high power. Mass transportation infrastructure use cases avalible, already works in many EU countries! Radio module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, HW projects cooperation avalible . Specialy designed for higher volume of clients & loads. CE RED, IC Canada  and FCC certified and full test reports available! FCC 4,9GHZ Certified!
It is based on XB140 reference design from the QCA for QCA9880 chipset. XB140 is a dual band 802.11ac design.  What are the differences between XB140 and WDS 600VX / 900VX?
WLE WDS 600VX / 900VX changes the FEM, power, some RF circuit and layout. We change the FEM, that is because we always work with the Skyworks;
we change the power, we change the RF and the layout for higher performance and lower working temperature, and we do many tests for it. Please chek our test reports in Blog section.
Our products are designed for higher numbers of clients connections & support for extreme loads. Very popular for Profi Hot-Spots and Internet for passengers applications!
Do you like our WiFi modules and want to test samples ? No problem ! Please contact us and provide your project description!
Specifications
