[资料] JEDEC Package Outline Spec 索引
920 查看
 楼主 | 发布于 2018-10-16 | 只看楼主
为了方便大家快速找到对应的资料,建立了这个索引表,建议直接在论坛里搜索 Spec No.
Spec No. Content
MO054 Registration - Zig-Zag In-Line Package (ZIP) Family, 2.54 mm Row Spacing, 16 Pin
MO055 Registration - Ceramic Single-In-Line Package (SIP) Family
MO056 Registration -Ceramic .025 inch Center Chip Carrier
MO057 Registration -Ceramic .020 inch Center Chip Carrier
MO059 Small Outline (SO) Package Family 8.4 mm (.330 inch) Body Width (Plastic) with Increased Lead Thickness to 11.8 mil max
MO062 Registration - 148 Pin Leadless Ceramic Chip Carrier .025 inch mil Pitch
MO063 Registration -Plastic Small Outline J-Lead (SOJ) .350 inch Wide Body, .050 inch Lead Spacing, 26.20 Pin
MO065 Registration - Plastic Small Outline J-Lead (SOJ) .300 inch Wide Body Family, 0.050 Lead Spacing, 24 and 26 Pins
MO066 Registration - .100 inch Center Ceramic Pin Grid Array Family (Small Outline)
MO067 Registration - .100 inch Center Ceramic Pin Grid Array Family (Large Outline)
MO068 Registration - Edge Clip SIP Module Family, .100 Row Centers. Addition of Variation AF.
MO069 Registration - Plastic Quad Flatpack .025 inch Lead Spacing (Gullwing).
MO070 Registration - Rectangular Ceramic .375 inch Nominal Width Flatpack Family
MO071 Registration - Plastic Thin Lead Package Family Square (Gullwing)
MS001 Standard - Dual-In-Line Plastic Family .300 inch Row Spacing. R-PDIP-T
MS002 Standard - .050 inch Leadless Chip Carrier, Type A. Variations AA-AH
MS003 Standard - .050 inch Leadless Chip Carrier, Type B. Variation BA-BH
MS004 Standard - .050 inch Center Leadless Chip Carrier, Type C. Variations CA-CH
MS005 Standard - .050inch Center Leadless Chip Carrier, Type D. Variations DA-DH
MS006 Standard - .050 inch Center Leaded Chip Carrier, 24 Terminal Leaded, Type A
MS007 Standard - .050 inch Center Lead Chip Carrier, Type A. Variations AA-AH
MS008 Standard - .050 inch Center Lead Chip Carrier, Type B. Variations BA-BH
MS009 Standard - .040 inch Center Leadless Chip Carrier Packages. Variations AA-AJ
MS010 Standard - Plastic DIP .400 inch Row Spacing, 28 and 32 Leads. Addition of Variations AC and AD
MS011 Standard - Plastic DIP .600 inch Row Spacing, 48 Lead. Addition of Variation AD
MS012 Standard - Plastic Dual Small Outline (SO) Family, Gull Wing, 1.27 mm Pitch Package
MS013 Standard - Very Thick Profile, Plastic Small Outline (SO) Family, 1.27 mm pitch, 7.50 mm (.300 inch) Body Width. B1R-PDSO.SOP.SOIC
MS014 Standard - Single Layer Chip Carrier Family, .040 inch Terminal Spacing, Ceramic. Variations AA-AJ
MS015 Standard - Side Brazed Ceramic DIPs in .300 inch, .400 inch and .900 inch Center Line Row-to-Row Spacing
MS016 Standard - Plastic Chip Carrier (PCC) Family, 1.27 mm(0.050 inch) Lead Spacing, Rectangular
MS017 Standard - Ceramic PGA .100 inch Pitch Cavity Down
MS018 Standard - Square Plastic Chip Carrier Family, (1.27 mm).050 inch Pitch
MS019 Standard - Dual-In-Line (Shrink .070 inch) Plastic Package Family .300 inch Row Spacing. R-PDIP-T
MS020 Standard - Dual-In-Line (Shrink .070 inch) Plastic Package Family .600 inch Row Spacing. R-PDIP-T
MS021 Standard - Dual-In-Line (Shrink .070 inch) Plastic Package Family .750 inch Row Spacing. R-PDIP-T
MS022 Standard - Metric Plastic Quad Flat Pack 1.0,0.8,0.65 mm
MS023 Standard - Plastic SOJ, .300 inch Body, .050 inch Lead Spacing
MS024 Standard - Thin Small Outline Package. TSOPII Package. This revision modifies leadframe thickness for 10.16 mm body SOIC family
MS025 Standard - TSOP II, 7.62 mm Body. Change to the Max. Bend Radius and Foot Angle
MS026 Standard - Low.Thin Profile Plastic Quad Flat Package, 2.00 mm Footprint, Optional Heat
MS027 Standard - Small Outline J-Lead (SOJ) Family, .400 inch Wide Body. PDSO-J
MS028 Standard - Addition of Rectangular BGA Variations to BGA Family
MS029 Standard - Fine Pitch Plastic Quad Flat Package Outline 2.6 mm Footprint
MS030 Standard - Ceramic Dual-In-Line (CDIP) Family, .300 inch Row Spacing
MS031 Standard - Ceramic Dual-In-Line (CDIP) Family, .400 inch Row Spacing
MS032 Standard - Ceramic Dual-In-Line (CDIP) Family, .600 inch Row Spacing
MS033 Standard - Ceramic Dual Flatpack (CerPak) Package Family, .050 inch Pitch
MS034 Standard - Ball Grid Array Family, Square, 1.27 mm, and 1.50 mm Pitch. S-PBGA.PBGA
MS072 Registration - 40 Lead Zig-Zag In-Line Package Family (ZIP) 0.500 inch Max Seated Height. Addition of Variation AE
MS073 Registration - Ceramic Top Brazed Dual-In-Line Package (DIP) Family .900(22.86) Row Spacing
MS074 Registration - Ceramic Bottom Brazed Dual-In-Line Package (DIP) Family .900(22.86) Row Spacing
MS075 Registration - .050 inch Center Non-Hermetic Leadless Chip Carrier Quad Series, Square
MS076 Registration - .050 inch Center Non-Hermetic Leadless Chip Carrier SO Series, Rectangular
MS077 Registration - Small Outline J-Lead (SOJ) .300 inch Body, .050 inch Lead Spacing. Addition of a 42 Lead Package.
MS078 Registration - Hermetic Flange-Mounted Header Family, Peripheral Leads, .100 mil Pitch, 5 Leads.
回复于 2018-10-16 沙发
不错,感谢分享;
回复于 2018-10-20 2#
回复于 2018-10-21 3#
感谢分享,有需要机器人方案,电源方案,开发板,控制板,驱动板 的可联系我,相互学习,共同进步
回复于 2018-10-22 4#
回复于 2018-10-24 5#
回复于 2022-02-03 6#
