[资料] 用于 C2000 实时控制开发套件的 F28379D controlCARD
1133 查看
16 回复
 楼主 | 发布于 2018-09-28 | 只看楼主
描述
The Delfino F28379D controlCARD from Texas Instruments is Position Manager-ready and an ideal product for initial software development and short run builds for system prototypes, test stands, and many other projects that require easy access to high-performance controllers.  All C2000 controlCARDs are complete board-level modules that utilize a HSEC180 or DIMM100 form factor to provide a low-profile single-board controller solution. The host system needs to provide only a single 5V power rail to the controlCARD for it to be fully functional.
特性
Supports the new DesignDRIVE Position Manager Technology - EnDat22, BiSS-C, SIN/COS, Resolver and incremental encoders when used with the IDDK
包含项目
楼主 | 回复于 2018-09-28 沙发
楼主 | 回复于 2018-09-28 2#
楼主 | 回复于 2018-09-28 4#
楼主 | 回复于 2018-09-28 6#
楼主 | 回复于 2018-09-28 7#
楼主 | 回复于 2018-09-28 9#
楼主 | 回复于 2018-09-28 10#
