[原创] 分享下基于STM32F030+CS5532的驱动设计
977 查看
 楼主 | 发布于 2018-09-25 | 只看楼主
做CS5532的驱动的时候,发现好多网上的代码不全,这个底层驱动基本都是自己写的,可以完美驱动CS5532,常用的寄存器配置都做了宏的定义。可以完美移植到其他MCU中。
#ifndef __CS5532_H__
#define __CS5532_H__
#include "stm32f0xx_hal.h"
#include "main.h"
#include "com.h"
//SDI 从器件输入,主器件输出
//SDO 从器件输出,主器件输入
#define Set_CS5532_SCLK_High()  HAL_GPIO_WritePin(CS5532_SCK_GPIO_Port,CS5532_SCK_Pin,GPIO_PIN_SET)
#define Set_CS5532_SCLK_Low()   HAL_GPIO_WritePin(CS5532_SCK_GPIO_Port,CS5532_SCK_Pin,GPIO_PIN_RESET)
#define Set_CS5532_SDI_High()   HAL_GPIO_WritePin(CS5532_SDI_GPIO_Port,CS5532_SDI_Pin,GPIO_PIN_SET)
#define Set_CS5532_SDI_Low()    HAL_GPIO_WritePin(CS5532_SDI_GPIO_Port,CS5532_SDI_Pin,GPIO_PIN_RESET)
#define Read_CS5532_SDO_Data()  HAL_GPIO_ReadPin(CS5532_SDO_GPIO_Port,CS5532_SDO_Pin)
//The CS5532-ASZ comm define
#define SYNC1 	        0xFF
#define SYNC0		        0xFE
#define CS5532_NULL   	0x00
#define  W_ALL_OFFSET_REG		0x41
#define  R_ALL_OFFSET_REG		0x49
#define  W_ALL_GAIN_REG			0x42
#define	 R_ALL_GAIN_REG			0x4A
#define  W_ALL_SETUP_REG		0x45
#define	 R_ALL_SETUP_REG		0x4D
#define  W_OFFSET_REG1			0x01
#define	 R_OFFSET_REG1			0x09
#define	 W_OFFSET_REG2			0x11
#define	 R_OFFSET_REG2			0x19
#define	 W_OFFSET_REG3			0x21
#define	 R_OFFSET_REG3			0x29
#define	 W_OFFSET_REG4			0x31
#define	 R_OFFSET_REG4			0x39
#define  W_GAIN_REG1			0x02
#define	 R_GAIN_REG1			0x0A
#define	 W_GAIN_REG2			0x12
#define	 R_GAIN_REG2			0x1A
#define	 W_GAIN_REG3			0x22
#define	 R_GAIN_REG3			0x2A
#define	 W_GAIN_REG4			0x32
#define	 R_GAIN_REG4			0x3A
#define  W_SETUP_REG1			0x05
#define  R_SETUP_REG1			0x0D
#define  W_SETUP_REG2			0x15
#define  R_SETUP_REG2			0x1D
#define  W_SETUP_REG3			0x25
#define  R_SETUP_REG3			0x2D
#define  W_SETUP_REG4			0x35
#define  R_SETUP_REG4			0x3D
#define  W_CONFIG_REG			0x03
#define  R_CONFIG_REG			0x0B
#define  START_SINGLE        (0x80)
#define  START_CONTINUOUS    (0xC0)
#define SETUP1 (0x00<<3)
#define SETUP2 (0x01<<3)
#define SETUP3 (0x02<<3)
#define SETUP4 (0x03<<3)
#define SETUP5 (0x04<<3)
#define SETUP6 (0x05<<3)
#define SETUP7 (0x06<<3)
#define SETUP8 (0x07<<3)
// Configuration Register
#define  STANDBY_MODE        (0x00L<<31)//
#define  SLEEP_MODE          (0x01L<<31)//
#define  POWER_SAVE_MODE     (0x01L<<30)  //
#define  NORMAL_MODE         (0x00L<<29)    //
#define  SYSTEM_RESET        (0x01L<<29)  //
#define  RESET_STATUS        (0x01L<<28)   //
#define  NORMAL_INPUTS       (0x00L<<27)   //
#define  SHORT_INPUTS        (0x01L<<27)   //
#define  VREF_HIGH           (0x00L<<25)  //2.5V-VA+
#define  VREF_LOW            (0x01L<<25)//
#define  CR_A1_0             (0x00L<<24)
#define  CR_A1_1             (0x01L<<24)
#define  CR_A0_0             (0x00L<<23)
#define  CR_A0_1             (0x01L<<23)
#define  LINE_FREQ_60        (0x00L<<19)  //
#define  LINE_FREQ_50        (0x01L<<19)  //5/6
//=== Channel Setup Register ===
//Channel Select Bits
#define SWITCH_CH1 (0x00L<<30)   //CS1=0,CS0=0
#define SWITCH_CH2 (0x01L<<30)   //CS1=0,CS0=1
//Gain Bits
#define Gain1     (0x00L<<27)
#define Gain2     (0x01L<<27)
#define Gain4     (0x02L<<27)
#define Gain8     (0x03L<<27)
#define Gain16    (0x04L<<27)
#define Gain32    (0x05L<<27)
#define Gain64    (0x06L<<27)
//Converter Speed  FRS=0
#define  DATARATE_100        (0x00L<<23)   //
#define  DATARATE_50         (0x01L<<23)
#define  DATARATE_25         (0x02L<<23)
#define  DATARATE_12P5       (0x03L<<23)
#define  DATARATE_6P25       (0x04L<<23)
#define  DATARATE_3200       (0x08L<<23)
#define  DATARATE_1600       (0x09L<<23)
#define  DATARATE_800        (0x0aL<<23)
#define  DATARATE_400        (0x0bL<<23)
#define  DATARATE_200        (0x0cL<<23)
//power mode
#define  BIPOLAR_MODE        (0x00L<<22)  //
#define  UNIPOLAR_MODE       (0x01L<<22)//
//=== Gain Register ===
#define  GAIN_32        (0x01L<<29)
#define  GAIN_16        (0x01L<<28)
#define  GAIN_8        (0x01L<<27)
#define  GAIN_4        (0x01L<<26)
#define  GAIN_2        (0x01L<<25)
#define  GAIN_1        (0x01L<<24)
#define AD_CH2  START_SINGLE+SETUP1
#define AD_CH1  START_SINGLE+SETUP3
void WriteCs5532Byte(uint8_t da);
uint8_t ReadCs5532Byte(void);
void WriteCs5532Dword(uint32_t da);
extern uint8_t ReadCs5532AD(uint8_t ADCHANNEL,uint32_t *out);
extern void cs5532_init(void);
#endif
#include "cs5532.h"
// 函数: void WriteCs5532Byte(uint8_t da)
// 描述: 给CS5532写1个字节的数据
// 参数: 给CS5532写入的数据,1个字节
// 返回: non
// 说明: non
// 版本: V1.0, 2018-09-07
  uint8_t i;
  Set_CS5532_SCLK_Low();
  for(i=0;i<8;i++)
    if((da&0x80)==0x80)
      Set_CS5532_SDI_High();
    else
      Set_CS5532_SDI_Low();
    Set_CS5532_SCLK_High();
    __NOP();
    __NOP();
    __NOP();
    __NOP();
    da = da<<1;
// 函数: uint8_t ReadCs5532Byte(void)
// 描述: CS5532读出一个字节的数据
// 参数: non
// 返回: CS5532读出的一个字节数据
// 说明: non
  uint8_t i,dat;
  for(i=0;i<8;i++)
    dat = dat<<1;
    if(Read_CS5532_SDO_Data() == GPIO_PIN_SET)
      dat = dat|0x01;
    __NOP();
    __NOP();
    __NOP();
    __NOP();
  return dat;
// 函数: void WriteCs5532Dword(uint32_t da)
// 描述: 给CS5532写4个字节的数据
// 参数: 给CS5532写入的数据,long类型,32位数据
// 返回: non
// 说明: non
    union type1
        uint8_t ch[4];
        uint32_t lon;
   union type1 temp;
   temp.lon= da;
    WriteCs5532Byte(temp.ch[3]);
    WriteCs5532Byte(temp.ch[2]);
    WriteCs5532Byte(temp.ch[1]);
    WriteCs5532Byte(temp.ch[0]);
// 函数: static uint32_t ReadCs5530(void)
// 描述: 读取CS5532的数据
// 参数: 1.选择AD的通道  2.读出的AD数据的地址指针
// 返回: 1:读取AD OK  0:读取AD溢出
// 说明: 参数1:AD_CH1和AD_CH2
// 版本: V1.0, 2018-09-14
    union type1
        uint8_t ch[4];
        uint32_t lon;
   static union type1 temp;
   WriteCs5532Byte(ADCHANNEL);
   while(Read_CS5532_SDO_Data() != GPIO_PIN_RESET);
   WriteCs5532Byte(CS5532_NULL);
   temp.ch[3] = ReadCs5532Byte();
   temp.ch[2] = ReadCs5532Byte();
   temp.ch[1] = ReadCs5532Byte();
   temp.ch[0] = ReadCs5532Byte();
//   UART1_Waite_SendByte(temp.ch[0]);
   if((temp.ch[0]&0x04)==0x04)
     return 0;//
    temp.lon = temp.lon>>8;
   *out = temp.lon;
   return 1;
// 函数: static void cs5532_init(void)
// 描述: CS5530的初始化,固定速度为15sps
// 参数: non
// 返回: non
// 说明: non
  uint8_t loop;
  uint32_t da;
//  //延时20ms,等待晶振启动
  HAL_Delay(20);
//  //发送ADC串口复位指令,初始化ADC到可访问状态
//  //发送SYNC1命令字,至少15个,这里发送30个
	for (loop=0;loop<30;loop++)
    WriteCs5532Byte(SYNC1);
//  //发送一个SYNC0命令字
	WriteCs5532Byte(SYNC0);
//	//启动系统复位
  WriteCs5532Byte(W_CONFIG_REG);//写配置寄存器
  WriteCs5532Dword(SYSTEM_RESET);
  HAL_Delay(20); //直接延时,不进行复位成功的循环检测
////  复位后读取配置寄存器的时候需要连续读两次,第一次RV为1,第二次RV为0
  WriteCs5532Byte(R_CONFIG_REG);//读配置寄存器
  ReadCs5532Byte();
  ReadCs5532Byte();
  ReadCs5532Byte();
  ReadCs5532Byte();
  ReadCs5532Byte();
  ReadCs5532Byte();
  ReadCs5532Byte();
  ReadCs5532Byte();
//  WriteCs5532Dword(NORMAL_MODE+LINE_FREQ_50+NORMAL_INPUTS); //正常输入,FRS=1
  WriteCs5532Dword(NORMAL_MODE+LINE_FREQ_50+SHORT_INPUTS); //正常输入,FRS=1
  WriteCs5532Byte(W_SETUP_REG1);//写通道设置寄存器1,物理通道1,速度12.5sps,增益4
  WriteCs5532Dword(SWITCH_CH1+Gain1+DATARATE_12P5+UNIPOLAR_MODE); //
  WriteCs5532Byte(W_SETUP_REG2);//写通道设置寄存器2,物理通道2,速度12.5sps,增益4
  WriteCs5532Dword(SWITCH_CH2+Gain1+DATARATE_12P5+UNIPOLAR_MODE); //
// 函数: uint8_t  TestChannelA(void)
// 描述: 读取CS5532的通道A状态
// 参数: non
// 返回: 1.CS5532通道A正常  0.CS5532通道A异常
// 说明: 物理通道0
// 版本: V1.0, 2018-09-17
  uint32_t da;
  if(ReadCs5532AD(AD_CH1,&da) == 1)
      if((da&0x00000007) == 0x00000000)
        return 1;
  return 0;
// 函数: uint8_t  TestChannelB(void)
// 描述: 读取CS5532的通道B状态
// 参数: non
// 说明: 物理通道1
  uint32_t da;
  if(ReadCs5532AD(AD_CH2,&da) == 1)
      if((da&0x00000007) == 0x00000001)
        return 1;
  return 0;
回复于 2018-09-25 沙发
回复于 2018-09-25 2#
谢谢分享!!!!!!!
回复于 2018-09-26 3#
回复于 2018-09-30 4#
回复于 2018-10-19 5#
感谢分享,有需要机器人方案的可联系我,相互学习,共同进步
