首页 论坛 原厂专区 ST MCU STM32F091 TIM16 输入捕获不进中断,请大神指点
[求助] STM32F091 TIM16 输入捕获不进中断,请大神指点
1171 查看
8 回复
 楼主 | 发布于 2018-09-04 | 只看楼主
如题,在用STM32F091的TIM16作为输入捕获中断时,不进中断,请大神们指点。代码如下:
IO口配置:
RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOE, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
    GPIO_Init(GPIOE, &GPIO_InitStructure);
  GPIO_SetBits(GPIOE,GPIO_Pin_0);
  GPIO_SetBits(GPIOE,GPIO_Pin_1);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource0, GPIO_AF_0);//TIM17_CH1
GPIO_PinAFConfig(GPIOE, GPIO_PinSource1, GPIO_AF_0);//TIM16_CH1
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM16 , ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM17 , ENABLE);
TIM_TimeBaseStructure.TIM_Prescaler = 4800;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseStructure.TIM_Period =10;
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM16, &TIM_TimeBaseStructure);
    TIM_TimeBaseInit(TIM17, &TIM_TimeBaseStructure);
TIM_ICInitStructure.TIM_Channel=TIM_Channel_1;
    TIM_ICInitStructure.TIM_ICPolarity=TIM_ICPolarity_Rising;
    TIM_ICInitStructure.TIM_ICSelection=TIM_ICSelection_DirectTI;
    TIM_ICInitStructure.TIM_ICPrescaler=TIM_ICPSC_DIV1;
    TIM_ICInitStructure.TIM_ICFilter=0;
    TIM_ICInit(TIM16,&TIM_ICInitStructure);
  TIM_ICInit(TIM17,&TIM_ICInitStructure);
TIM_Cmd(TIM16, ENABLE);
    TIM_Cmd(TIM17, ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = TIM16_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPriority=0x02;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    TIM_ITConfig(TIM16,TIM_IT_CC1 ,ENABLE);
  TIM_ITConfig(TIM17,TIM_IT_CC1 ,ENABLE);
楼主 | 回复于 2018-09-04 沙发
void TIM16_IRQHandler(void)
 uint16_t temp=0;
 if(TIM_GetITStatus(TIM16,TIM_IT_CC1)!=RESET)
  WaterCNT++;
  WaterIncrease++;
  temp=TIM16->CNT;
  if(temp>FlowLastCNT)
   WaterSpeed= 600000/(temp-FlowLastCNT);
  else
   WaterSpeed= 600000/(temp+60000-FlowLastCNT);
  FlowLastCNT=temp;
 TIM_ClearITPendingBit(TIM16,TIM_IT_CC1);
回复于 2018-09-04 2#
这是072的仅供参考
  * @brief  Configure the TIM IRQ Handler.
  * @param  None
  * @retval None
static void TIM_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  TIM_ICInitTypeDef  TIM_ICInitStructure;
  /* TIM2 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* GPIOB clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  /* TIM2 chennel2 configuration : PB.03 */
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_3;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* Connect TIM pin to AF2 */
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_2);
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
    TIM2 configuration: PWM Input mode
     The external signal is connected to TIM2 CH2 pin (PB.03)
     TIM2 CCR2 is used to compute the frequency value
     TIM2 CCR1 is used to compute the duty cycle value
    In this example TIM2 input clock (TIM2CLK) is set to APB1 clock (PCLK1), since
    APB1 prescaler is set to 1.
      TIM2CLK = PCLK1 = HCLK = SystemCoreClock
    External Signal Frequency = SystemCoreClock / TIM2_CCR2 in Hz.
    External Signal DutyCycle = (TIM2_CCR1*100)/(TIM2_CCR2) in %.
  Note:
  SystemCoreClock variable holds HCLK frequency and is defined in system_stm32f0xx.c file.
  Each time the core clock (HCLK) changes, user had to call SystemCoreClockUpdate()
  function to update SystemCoreClock variable value. Otherwise, any configuration
  based on this variable will be incorrect.
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;
  TIM_PWMIConfig(TIM2, &TIM_ICInitStructure);
  /* Select the TIM2 Input Trigger: TI2FP2 */
  TIM_SelectInputTrigger(TIM2, TIM_TS_TI2FP2);
  /* Select the slave Mode: Reset Mode */
  TIM_SelectSlaveMode(TIM2, TIM_SlaveMode_Reset);
  TIM_SelectMasterSlaveMode(TIM2,TIM_MasterSlaveMode_Enable);
  /* TIM enable counter */
  TIM_Cmd(TIM2, ENABLE);
  /* Enable the CC2 Interrupt Request */
   TIM_ITConfig(TIM2, TIM_IT_CC2, ENABLE);
回复于 2018-09-04 3#
回复于 2018-09-05 4#
1.  检查下捕获中断是否开启;
2、外部是否有可捕获的事件过来;
3. 中断方面的配置要正确
4. 启动文件正确
回复于 2018-09-12 5#
支持下,谢谢分享
回复于 2018-09-23 6#
回复于 2018-10-19 7#
感谢分享,有需要机器人方案的可联系我,相互学习,共同进步
回复于 2019-02-09 8#
