[资料] MSP430平台 AM2301测量光强(已测试)
629 查看
 楼主 | 发布于 2018-08-29 | 只看楼主
AM2301.c
#include "AM2301.h"
int wendu=0;
unsigned int wet=0;
unsigned char check_flag=0;
void AN2301_init(void);
void int_am2301clk()
  unsigned char i;//定义局部变量i
  BCSCTL1&=~XT2OFF;//打开高频晶体震荡器
  BCSCTL2|=SELM1+SELS;//MCLK和SMCLK的时钟源都选择XT2CLK,即都是8MHZ
  do//(至少执行一次DO循环)
    IFG1&=~OFIFG;//清除晶体震荡出错标志位
    for(i=0;i<100;i++)
      _NOP();//简单的延时等待
  }while((IFG1&OFIFG));//判断晶体震荡是否出错,如果还是出错,则继续执行DO循环
  IFG1&=~OFIFG;
void delay_1us(unsigned int time_temp)
  unsigned int i;
  for(i=time_temp;i>0;i--)
    _NOP();
    _NOP();
    _NOP();
    _NOP();
unsigned char get_40_bits(void)
  unsigned int time_h=0;
  unsigned int time_l=0;
  unsigned char wet_h=0;
  unsigned char wet_l=0;
  unsigned char wendu_h=0;
  unsigned char wendu_l=0;
  unsigned char check=0;
  unsigned char i=0;
  data_out;//置为输出
  data_down;
  delay_1us(1000);//至少500us
  data_up;
  //启动模块
  data_in;
  delay_1us(10);//主机拉高20~40us
  time_h=0;
  while(data_h&&(time_h<60000))
    time_h++;
  time_l=0;
  while(data_l&&(time_l<60000))
    time_l++;
  time_h=0;
    time_h++;
  //准备接受数据
  for(i=0;i<8;i++)
    time_h=0;
    time_l=0;
      time_l++;
      time_h++;
    if(time_l<time_h)//数据 1
      wet_h|=(0x80>>i);
  for(i=0;i<8;i++)
    time_h=0;
    time_l=0;
      time_l++;
      time_h++;
      wet_l|=(0x80>>i);
  for(i=0;i<8;i++)
    time_h=0;
    time_l=0;
      time_l++;
      time_h++;
      wendu_h|=(0x80>>i);
  for(i=0;i<8;i++)
    time_h=0;
    time_l=0;
      time_l++;
      time_h++;
      wendu_l|=(0x80>>i);
  for(i=0;i<8;i++)
    time_h=0;
    time_l=0;
      time_l++;
      time_h++;
      check|=(0x80>>i);
  //接受40bit数据
  i=(unsigned char)(wet_h+wet_l+wendu_h+wendu_l);
  if(check==i)
    wet=wet_h;
    wet<<=8;
    wet+=wet_l;
    if((wendu_h&0x80)==0x00)//温度为正
      wendu=wendu_h;
      wendu<<=8;
      wendu+=wendu_l;
    else
      wendu_h&=0x80;
      wendu=wendu_h;
      wendu<<=8;
      wendu+=wendu_l;
      wendu=-wendu;
    check_flag=1;
    return 1;
  else
    check_flag=0;
    return 0;
void AM2301_init(void)
   P1SEL=0x00;
void AM2301()
    get_40_bits();
    delay_1us(60000);
楼主 | 回复于 2018-08-29 沙发
AM2301.h
#include "msp430x14x.h"
#define    data_out     (P1DIR|=0x01)
#define    data_in      (P1DIR&=0xFE)
#define    data_up      (P1OUT|=0x01)
#define    data_down    (P1OUT&=0xFE)
#define    data_h       ((P1IN&0x01)==0x01)
#define    data_l       ((P1IN&0x01)==0x00)
void AM2301(void);
void delay_1us(unsigned int time_temp);
unsigned char get_40_bits(void);
楼主 | 回复于 2018-08-29 2#
自己顶一下
回复于 2018-08-30 3#
楼主 | 回复于 2018-08-30 4#
感谢支持
