[资料] MSP430f149控制LCD12864显示汉字、字母
1496 查看
 楼主 | 发布于 2018-08-28 | 只看楼主
程序功能:在12864液晶上显示一屏汉字
测试说明:观察液晶显示
#include  "msp430.h"
#include  "msp430x14x.h"
#define LCD_DataIn    P4DIR=0x00    //数据口方向设置为输入
#define LCD_DataOut   P4DIR=0xff    //数据口方向设置为输出
#define LCD2MCU_Data  P4IN
#define MCU2LCD_Data  P4OUT
#define LCD_CMDOut    P6DIR|=0xFC     //P3口的低三位设置为输出
#define LCD_RS_H      P6OUT|=BIT2      //P6.2
#define LCD_RS_L      P6OUT&=~BIT2     //P6.2
#define LCD_RW_H      P6OUT|=BIT3      //P6.3
#define LCD_RW_L      P6OUT&=~BIT3     //P6.3
#define LCD_EN_H      P6OUT|=BIT4      //P6.4
#define LCD_EN_L      P6OUT&=~BIT4     //P6.4
#define LCD_PSB_H      P6OUT|=BIT5      //P6.5
#define LCD_PSB_L      P6OUT&=~BIT5     //P6.5
#define LCD_RST_H      P6OUT|=BIT6      //P6.6
#define LCD_RST_L      P6OUT&=~BIT6     //P6.6
void Delay_1ms(void);
void Delay(unsigned int n);
void Write_Cmd(unsigned char cod);
void Write_Data(unsigned char dat);
void Ini_Lcd(void);
void Disp_HZ(unsigned char addr,const unsigned char * pt,unsigned char num);
void Disp_ND(unsigned char addr,unsigned int  thickness);
void Draw_TX(unsigned char Yaddr,unsigned char Xaddr,const unsigned char * dp) ;
void Draw_PM(const unsigned char *ptr);
const char hang1[] = {"祥瑞不在凤凰麒麟"};
const char hang2[] = {"太平须得边将忠臣"};
const char hang3[] = {"但得百僚师长肝胆"};
const char hang4[] = {"不用三军罗绮金银"};
typedef unsigned char uchar;
typedef unsigned int  uint;
extern const unsigned char shuzi_table[];
/***************************主函数*************************/
void main( void )
    WDTCTL = WDTPW + WDTHOLD;    //关狗
    Ini_Lcd();                  //初始化液晶
    Disp_HZ(0x80,hang1,8);
    Disp_HZ(0x90,hang2,8);
    Disp_HZ(0x88,hang3,8);
    Disp_HZ(0x98,hang4,8);
    LPM4;
函数名称:Delay_1ms
功    能:延时约1ms的时间
参    数:无
返回值  :无
	uchar i;
	for(i = 150;i > 0;i--)  _NOP();
函数名称:Delay_Nms
功    能:延时N个1ms的时间
参    数:n--延时长度
返回值  :无
void Delay_Nms(uint n)
    uint i;
    for(i = n;i > 0;i--)    Delay_1ms();
函数名称:Write_Cmd
功    能:向液晶中写控制命令
参    数:cmd--控制命令
返回值  :无
void Write_Cmd(uchar cmd)
    uchar lcdtemp = 0;
    LCD_RS_L;
    LCD_RW_H;
    LCD_DataIn;
    do                       //判忙
        LCD_EN_H;
       	_NOP();
       	lcdtemp = LCD2MCU_Data;
       	LCD_EN_L;
    while(lcdtemp & 0x80);
    LCD_DataOut;
    LCD_RW_L;
    MCU2LCD_Data = cmd;
    LCD_EN_H;
    _NOP();
    LCD_EN_L;
函数名称:Write_Data
功    能:向液晶中写显示数据
参    数:dat--显示数据
返回值  :无
void  Write_Data(uchar dat)
    uchar lcdtemp = 0;
    LCD_RS_L;
    LCD_RW_H;
    LCD_DataIn;
    do                       //判忙
        LCD_EN_H;
        _NOP();
        LCD_EN_L;
    LCD_DataOut;
    LCD_RS_H;
    LCD_RW_L;
    MCU2LCD_Data = dat;
    LCD_EN_H;
    _NOP();
    LCD_EN_L;
函数名称:Ini_Lcd
功    能:初始化液晶模块
参    数:无
返回值  :无
void Ini_Lcd(void)
  	LCD_RST_L;                            //复位LCD
        Delay_1ms();                        	//保证复位所需要的时间
	LCD_RST_H;                            //恢复LCD正常工作
	_NOP();
	LCD_PSB_H;                            //设置LCD为8位并口通信
  LCD_CMDOut;    //液晶控制端口设置为输出
    Delay_Nms(500);
    Write_Cmd(0x30);   //基本指令集
    Delay_1ms();
    Write_Cmd(0x02);   // 地址归位
    Delay_1ms();
	Write_Cmd(0x0c);   //整体显示打开,游标关闭
    Delay_1ms();
	Write_Cmd(0x01);   //清除显示
    Delay_1ms();
	Write_Cmd(0x06);   //游标右移
    Delay_1ms();
	Write_Cmd(0x80);   //设定显示的起始地址
函数名称:Disp_HZ
功    能:控制液晶显示汉字
参    数:addr--显示位置的首地址
          pt--指向显示数据的指针
          num--显示字符个数
返回值  :无
void Disp_HZ(uchar addr,const uchar * pt,uchar num)
    uchar i;
    Write_Cmd(addr);
   	for(i = 0;i < (num*2);i++)
        Write_Data(*(pt++));
回复于 2018-08-29 沙发
感谢分享;
回复于 2018-08-30 2#
谢谢分享!!!!!!!!!!!
回复于 2018-08-30 3#
回复于 2018-08-30 4#
楼主 | 回复于 2018-08-30 5#
感谢支持
楼主 | 回复于 2018-08-30 6#
一起分享
回复于 2018-09-15 7#
支持下,谢谢分享
