[分享] 最新 SIGFOX 软件开发套件 STSW-S2LP-SFX-DK v1.5.0
1544 查看
15 回复
 楼主 | 发布于 2018-08-16 | 只看楼主
解压缩密码 : s2-lp
New Features
•Enhanced use of NVM. Now Flash memory can be used to store/retrieve credentials and Sigfox data
•Encryption tool to generate bin file for flash Sigfox credentials
•Support for X-NUCLEO-S2868A1
•Support for BlueNRG-1 and BlueNRG-2
•Command Line Interface (CLI)
◦Integrated start/stop Continous Modulation
◦Added new commands for set both frequency and RSSI offset and payload encryption
◦Added the node_send_bit command
◦Added the switch_test_credentials command in order to use test_credentials on registered boards
◦Added the node_open_with_zone command that allows to select RC Zone before open the library
•Added CLI in source code as new project sample
Correcionts/Changes
•Project libraries now integrate Sigfox Lib v2.5.0 as well as Sigfox ADDON v0.4.0.
•Command Line Interface (CLI) - Fixed version number bug
•Not registered board now automatically set ID and KEY for test
•Bugfixes
◦Fixed possible hangs during RX SENSI test
◦Fixed error with payload encryption
◦Fixed issue with HMAC encryption when using public key
Sub-1G S2-LP SIGFOX Spirit 系列
回复于 2018-11-22 11#
回复于 2018-11-22 12#
回复于 2018-11-22 13#
回复于 2018-12-30 14#
回复于 2019-02-10 15#
