[分享] 基于Python的示波器的截屏GUI界面
2016 查看
8 回复
 楼主 | 发布于 2018-04-21 | 只看楼主
import time
import tkinter as tk
from tkinter import *
from tkinter import ttk
class ScreenCapture(object):
    def __init__(self):
        self.idn = self.__class__.__name__
        # Instrument Initialisation
#        self.instr = MyInstruments()
        self.timestamp = time.strftime('%d-%b-%Y_%I.%M.%S_%p')
        self.results_folder = '%s%s%s' % ('./EvalData/', self.timestamp, '/')
    def gui_setup(self):
        # Title and window size
        win = tk.Tk()
        win.title("Screen Capture GUI")
        win.geometry('550x400')
        # CH Name Setting
        label1 = ttk.Label(win, text='CH1:LABEL:NAME').grid(column=0, row=0)
        text1 = tk.Text(width = 10, height = 1)
        text1.grid(column=1, row=0)
        text1.insert(INSERT,'LX1')
        label2 = ttk.Label(win, text='CH2:LABEL:NAME').grid(column=0, row=1)
        text2 = tk.Text(width = 10, height = 1)
        text2.grid(column=1, row=1)
        text2.insert(INSERT,'VOUT')
        label3 = ttk.Label(win, text='CH3:LABEL:NAME').grid(column=0, row=2)
        text3 = tk.Text(width = 10, height = 1)
        text3.grid(column=1, row=2)
        text3.insert(INSERT,'LX2')
        label4 = ttk.Label(win, text='CH4:LABEL:NAME').grid(column=0, row=3)
        text4 = tk.Text(width = 10, height = 1)
        text4.grid(column=1, row=3)
        text4.insert(INSERT, 'IOUT')
        # CH Offset Setting
        ttk.Label(win, text="CH1 Offset").grid(column=2, row=0)
        ch1offset = StringVar()
        ch1offset_set = Scale(win, from_=0, to=2, orient=HORIZONTAL, resolution=0.01, tickinterval=100, length=100, variable=ch1offset)
        ch1offset_set.grid(column=3, row=0)
        ttk.Label(win, text="CH2 Offset").grid(column=2, row=1)
        ch2offset = StringVar()
        ch2offset_set = Scale(win, from_=0, to=2, orient=HORIZONTAL, resolution=0.01, tickinterval=10, length=100, variable=ch2offset)
        ch2offset_set.grid(column=3, row=1)
        ttk.Label(win, text="CH3 Offset").grid(column=2, row=2)
        ch3offset = StringVar()
        ch3offset_set = Scale(win, from_=0, to=2, orient=HORIZONTAL, resolution=0.01, tickinterval=10, length=100, variable=ch2offset)
        ch3offset_set.grid(column=3, row=2)
        ttk.Label(win, text="CH4 Offset").grid(column=2, row=3)
        ch4offset = StringVar()
        ch4offset_set = Scale(win, from_=0, to=2, orient=HORIZONTAL, resolution=0.01, tickinterval=10, length=100, variable=ch4offset)
        ch4offset_set.grid(column=3, row=3)
        # Input Voltage setting
        ttk.Label(win, text="INPUT VOLTAGE[V]").grid(column=0, row=4)
        vin = tk.StringVar()
        vin_set = ttk.Combobox(win, width=10, textvariable=vin)
        vin_set['values'] = (2.5, 3.0, 3.5, 3.7, 4.0, 4.5, 5.0, 5.5)
        vin_set.grid(column=1, row=4)
        vin_set.current(3)
        # Output Current Setting
        ttk.Label(win, text="LOAD CURRENT[A]").grid(column=0, row=5)
        iout = tk.StringVar()
        iout_set = ttk.Combobox(win, width=10, textvariable=iout)
        iout_set['values'] = (0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0)
        iout_set.grid(column=1, row=5)
        iout_set.current(0)
        # Trigger choose and type setting
        ttk.Label(win, text="CH Num of Trigger").grid(column=0, row=6)
        number = tk.StringVar()
        numberChosen = ttk.Combobox(win, width=10, textvariable=number)
        numberChosen['values'] = ('CH1','CH2', 'CH3', 'CH4')
        numberChosen.grid(column=1, row=6)
        numberChosen.current(3)
        riseorfall = tk.StringVar()
        riseorfallChosen = ttk.Combobox(win, width=10, textvariable=riseorfall)
        riseorfallChosen['values'] = ('Rise','Fall')
        riseorfallChosen.grid(column=2, row=6)
        riseorfallChosen.current(1)
        # Screen Capture button
        action = ttk.Button(win, text="Screen Capture")
        action.grid(column=1, row=10)
        tk.mainloop()
if __name__ == '__main__':
    meas = ScreenCapture()
    try:
        meas.gui_setup()
    finally:
        pass
楼主 | 回复于 2018-04-21 沙发
抱歉。保存的时候格式出现问题了。。。
楼主 | 回复于 2018-04-21 2#
输出结果如下图:
回复于 2018-04-21 3#
THANKS
回复于 2018-04-21 4#
这个不错;
楼主 | 回复于 2018-04-21 5#
格式没法修改,各位有经验的可以指点一下。
回复于 2018-04-22 6#
这个不错,有人说Python做界面速度慢,楼主实际测试如何?
评论 (2) 举报
楼主 | 回复于 2018-04-23 7#
这个只是图形界面,和示波器建立通信稍后完善。
回复于 2018-04-23 8#
