首页 论坛 嵌入式软件专区 操作系统 A40i(工业级) & T3(车规级) 开机自启与屏幕配置 小窍门
[资料] A40i(工业级) & T3(车规级) 开机自启与屏幕配置 小窍门
436 查看
 楼主 | 发布于 2021-03-12 | 只看楼主
两款板卡均采用国产芯片设计研发,OKT3-C开发板基于全志四核车载导航处理器设计开发,OKA40i-C开发板基于全志 四核工业级处理器设计开发。
一、开机自启动方法
开机自启动脚本为/autorun.sh,可以将开机需要进行设置的命令可以在此脚本中加入。假设开机时自动执行/root/loop.sh,在/autorun.sh中加入:
source /root/loop.sh &
关闭开机启动qt程序。
修改/etc/init.d/rcS 注释掉runqt。
二、 LCD配置简介
针对A40i配置
RGB24 1024x600屏幕配置文件:
tools/pack/chips/sun8iw11p1/configs/OKA40i_C/sys_config1024x600.fex
LVDS 1280x800屏幕配置文件:
tools/pack/chips/sun8iw11p1/configs/OKA40i_C/sys_config1280x800.fex
MIPI1024x600屏幕配置文件:
tools/pack/chips/sun8iw11p1/configs/OKA40i_C/sys_config1024x600mipi.fex
RGB24 800x480屏幕配置文件:
tools/pack/chips/sun8iw11p1/configs/OKA40i_C/sys_config800x480.fex
hdmi独立显示 屏幕参数:
tools/pack/chips/sun8iw11p1/configs/OKA40i_C/sys_config1080p.fex
Ø 针对T3配置
tools/pack/chips/sun8iw11p1/configs/ OKT3_C/sys_config1024x600.fex
tools/pack/chips/sun8iw11p1/configs/ OKT3_C/sys_config1280x800.fex
MIPI1024x600屏幕配置文件:
tools/pack/chips/sun8iw11p1/configs/ OKT3_C/sys_config1024x600mipi.fex
tools/pack/chips/sun8iw11p1/configs/ OKT3_C/sys_config800x480.fex
hdmi独立显示 屏幕参数:
tools/pack/chips/sun8iw11p1/configs/ OKT3_C/sys_config1080p.fex
Ø 屏幕配置lcd0小节
[lcd0]
lcd_used            = 1
lcd_driver_name     = "default_lcd"
lcd_backlight       = 255
lcd_if              = 0
lcd_x               = 1024
lcd_y               = 600
lcd_width           =
lcd_height          =
lcd_dclk_freq       = 51
lcd_pwm_used        = 1
lcd_pwm_ch          = 0
lcd_pwm_freq        = 50000
lcd_pwm_pol         = 0
lcd_pwm_max_limit   = 255
lcd_hbp             = 320
lcd_ht              = 1505
lcd_hspw            = 1
lcd_vbp             = 35
lcd_vt              = 648
lcd_vspw            = 1
lcd_lvds_if         = 0
lcd_lvds_colordepth = 0
lcd_lvds_mode       = 0
lcd_frm             = 0
lcd_hv_clk_phase    = 0
lcd_hv_sync_polarity= 0
lcd_gamma_en        = 0
lcd_bright_curve_en = 0
lcd_cmap_en         = 0
deu_mode            = 0
lcdgamma4iep        = 22
smart_color         = 90
原文链接:https://www.forlinx.com/article_view_577.html
