[资料] AN2295 bootloader文档解析(三)
440 查看
 楼主 | 发布于 2020-10-14 | 只看楼主
1.  Boot loader例程烧录
    运行平台
Ø FRDM-KE02
Ø IAR ARM IDE
    运行例程(IAR)
1)    使用USB cable连接FRDM-KE02开发板Min-B USB连接器(J6);
2)    加载GPIO工程后,选择【FLASH_128KB】,点击
进行编译;
3)    编译成功后,点击
进入调试界面;
            4)    进入调试界面后,点击
            运行例程。
1.  Boot loader上位机使用手册
1)    解压AN2295代码包后,在\an2295sw\masters\debug路径下,打开“win_hc08sprg.exe”
 1
       1)    生成User code的S19文件
Ø                 修改User code工程的linker file文件(以IAR ICF file为例)
            /*###ICF### Section handled by ICF editor, don't touch! ****/
            /*-Editor annotation file-*/
            /* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
            /*-Memory Regions-*/
            //define symbol __ICFEDIT_region_ROM_start__ = 0;                                                           //修改前
            define symbol __ICFEDIT_region_ROM_start__ = 0x00001000;                                           //修改后
            define symbol __ICFEDIT_region_ROM_end__   = (64*1024) -1;//********
            define symbol __ICFEDIT_region_RAM_end__   = 0x20000000;
            define symbol __ICFEDIT_region_RAM_start__ =__ICFEDIT_region_RAM_end__ - (4*1024)/4 + 0x410;//********
            define symbol __region_EEPROM_start__      = 0x10003100;
            define symbol __region_EEPROM_end__        = __region_EEPROM_start__ -1 + 256; // 256 bytes
            /*-Specials-*/
            define symbol __ICFEDIT_intvec_start__     = __ICFEDIT_region_ROM_start__;
            /*-Sizes-*/
            define symbol __ICFEDIT_size_cstack__ = (1*1024);//********
            define symbol __ICFEDIT_size_heap__   = (1*1024);//********
            /**** End of ICF editor section. ###ICF###*/
            define symbol __region_RAM2_start__        = 0x20000000;
            define symbol __region_RAM2_end__          = __region_RAM2_start__ + ((4*1024)*3)/4;//********
            //define exported symbol __VECTOR_TABLE      = 0x00000000;                           //修改前
            define exported symbol __VECTOR_TABLE      = 0x00001000;                             //修改后
            define exported symbol __VECTOR_RAM        = __ICFEDIT_region_RAM_start__ - 0x410;
            define exported symbol __BOOT_STACK_ADDRESS = __region_RAM2_end__ - 8;
            define symbol __code_start__ = __ICFEDIT_region_ROM_start__ + 0x410;//********
            define memory mem with size = 4G;
            define region ROM_region   = mem:[from __ICFEDIT_region_ROM_start__   to __ICFEDIT_region_ROM_end__] | mem:[from __region_EEPROM_start__ to __region_EEPROM_end__];//********
            define region RAM_region   = mem:[from __ICFEDIT_region_RAM_start__   to __region_RAM2_end__] | mem:[from __region_RAM2_start__ to __region_RAM2_end__];
            define block CSTACK    with alignment = 8, size = __ICFEDIT_size_cstack__   { };
            define block HEAP      with alignment = 8, size = __ICFEDIT_size_heap__     { };
            initialize manually { readwrite };
            initialize manually { section .data};
            initialize manually { section .textrw };
            do not initialize  { section .noinit };
            define block CodeRelocate { section .textrw_init };
            define block CodeRelocateRam { section .textrw };
            place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };
            place at address mem:__code_start__ { readonly section .noinit };
            place in ROM_region   { readonly, block CodeRelocate};
            place in RAM_region   { readwrite, block CodeRelocateRam,
                                      block CSTACK, block HEAP };
Ø                    生成S19文件设置
l  选中工程后,右击后并单击【Options】,图2所示;
 2
l  勾选【Generate additional output】,并选择【Motorola】作为Output format,如图3所示;
 3
 l  勾选【Override default】,可修改生成文件的文件名,最后单击【OK】,如图4所示;
 4
1)    上位机与FRDM-KE02建立连接
图 5
Ø  1】:选择合适的COM;
Ø  2】 :  选择协定好的波特率;
Ø  3】:选择User code工程生成的S19文件;
Ø  4】:点击Connect,接着复位Target,使得Boot loader例程重新运行。
4)    User code更新
       经上述3步骤后,上位机的Identification框中会显示Boot loader的相关属性信息(如图6所示),同时主窗口还显示了MCU的封装形式、Flash特性、中断向量表重定向地址、User code所占Flash空间等信息,表明了上位机与Target连接建立成功,接着点击【Program】,即可实现User code更新,如图7所示。
 6
