[原创] 什么叫EMC?
912 查看
8 回复
 楼主 | 发布于 2020-03-02 | 只看楼主
电磁兼容性(EMC)Electromagnetic Compatibility 官方定义
Definition - What does Electromagnetic Compatibility mean?  Electromagnetic compatibility (EMC) is the ability of different electronic devices and components to work correctly even in the presence of other devices that emit electromagnetic waves. This means that each piece of equipment emitting EM waves or disturbances must have it limited to a certain level and that each individual device must have adequate immunity to EM disturbances in the environment it is meant to function in.
      是指设备或系统在其电磁环境中符合要求运行并不对其环境中的任何设备产生无法忍受的电磁干扰的能力。因此,EMC包括两个方面的要求:一方面是指设备在正常运行过程中对所在环境产生的电磁干扰不能超过一定的限值;另一方面是指器具对所在环境中存在的电磁干扰具有一定程度的抗扰度,即电磁敏感性。
回复于 2020-03-02 沙发
楼主 | 回复于 2020-03-02 2#
这是分享的开端,加油!
回复于 2020-03-06 3#
回复于 2020-03-06 4#
回复于 2020-03-09 5#
回复于 2020-03-09 6#
回复于 2020-03-18 7#
回复于 2020-08-19 8#
