[原创] 关于在HAL库下STM32F103移植ucosIII的几点注意事项
1497 查看
 楼主 | 发布于 2020-02-13 | 只看楼主
1.找到ucosIII的源码,这里我找到的是野火提供的官方的基于Eval-STM32F107的源码。
2.MDK新建工程,添加ucosIII的.c和.h文件,这些就不必说了,是通用的做法。
3.修改启动文件,把原来的PendSV_Handler函数和SysTick_Handler函数替代为OS_CPU_PendSVHandler和OS_CPU_SysTickHandler,总共有三个地方需要修改。
4.在stm32f1xx_it.c中把PendSV_Handler和SysTick_Handler函数屏蔽掉。.h中的声明也屏蔽掉。
5.在stm32f1xx_hal_msp.c中增加CPU_TS_TmrInit和CPU_TS_TmrRd的定义
  * @brief  Timestamp initialization function
  * @param  None
  * @retval None
#if (CPU_CFG_TS_TMR_EN == DEF_ENABLED)
void  CPU_TS_TmrInit (void)
#endif
  * @brief  Read timestamp function
  * @param  None
  * @retval None
CPU_TS_TMR  CPU_TS_TmrRd (void)
    return (SysTick->VAL);
#endif
6.在系统的时钟初始化中配置systick的时钟源和嘀嗒时间。以及设置中断的优先级层数。
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.Prediv1Source = RCC_PREDIV1_SOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  RCC_OscInitStruct.PLL2.PLL2State = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
  /** Configure the Systick interrupt time
//  __HAL_RCC_PLLI2S_ENABLE();
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
7.配置只有一个任务ucos系统,使ucos运行起来,闪烁一个led。定义一个任务的三要素,任务栈,任务控制块,任务主题函数即可。
int main(void)
    OS_ERR err;
    BSP_Init();
    CPU_Init();
  OSInit(&err);
  while (1)
        HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_0);
//        USART1_SendByte(0xAA);
            delay_ms(1000);
//        printf("** Test finished successfully. ** \r\n");
//            Key_Out(0x00);
//    OSTaskCreate((OS_TCB *)&MyTaskTCB,
//                         (CPU_CHAR *)"MyTask",
//                         (OS_TASK_PTR)&MyTask,
//                         (void *)0,
//                         (OS_PRIO) APP_TASK_START_PRIO,
//                         (CPU_STK *)&MyTaskStk[0],
//                         (CPU_STK_SIZE)APP_TASK_START_STK_SIZE / 10,
//                         (CPU_STK_SIZE)APP_TASK_START_STK_SIZE,
//                         (OS_MSG_QTY)0,
//                         (OS_TICK)0,
//                         (void *)0,
//                         (OS_OPT)(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
//                         (OS_ERR *)&err);
//  OSStart(&err);
  /* Infinite loop */
  while (1)
8.着重要注意的是,我们需要测试单独外设功能的时候,需要先初始化ucos,在创建任务之前加入原来的while循环函数即可,不然原来的函数会无法运行的。
int main(void)
    OS_ERR err;
    BSP_Init();
    CPU_Init();
  OSInit(&err);
  while (1)
            delay_ms(1000);
//            Key_Out(0x00);
//                         (void *)0,
//                         (OS_MSG_QTY)0,
//                         (OS_TICK)0,
//                         (void *)0,
//                         (OS_ERR *)&err);
//  OSStart(&err);
  /* Infinite loop */
  while (1)
回复于 2020-02-13 沙发
回复于 2020-02-16 2#
回复于 2020-02-18 3#
回复于 2020-02-23 4#
回复于 2020-02-29 5#
