首页 论坛 原厂专区 ST MCU STM32 固件版权常​见问题(STM32 Firmware Copyright
[分享] STM32 固件版权常​见问题(STM32 Firmware Copyright
743 查看
11 回复
 楼主 | 发布于 2020-01-06 | 只看楼主
        STM32 固件版权常见问题
1Q.       STM32固件是否包含ST版权资料?
1A.       是。
2Q.      非ST微处理器上使用STM32固件?
2A.       除非拥有特许证书许可,STM32固件只能配合ST微处理器使用。
3Q.       我是否能在非ST微处理器上使用改写过的STM32固件?
3A.        除非拥有特许证书许可,改写过的STM32固件只能配合ST微处理器使用。
4Q.       我能改写并以我个人的自有版权再传播STM32固件吗?
4A.       除非拥有特许证书许可,经改写的STM32固件的再传播必须取得符合许可条件的适用版权声明。
楼主 | 回复于 2020-01-06 沙发
5Q.       如果我传播或者使用侵犯了ST版权的第三方固件,我要对侵权负责吗?
5A.       是的,任何人使用或者再销售侵犯ST版权的第三方代码,也要对侵权负责。
6Q.       如果我从Github上下载STM32固件,我可以按自己的意愿自由使用吗?
6A.        不可以。所有STM32固件的使用,都要遵守许可证书的特殊条款和条件的规定,无论来源。
7Q.       我是否能在非ST 微处理器上使用STM32工具?
7A.       STM32工具只能配合ST微处理器执行使用。
==================================中文版结束 ==================================
楼主 | 回复于 2020-01-06 2#
  STM32 Firmware Copyright FAQ
1Q.       Does STM32 firmware include ST copyrighted materials ?
1A.       Yes.
2Q.      Can I use STM32 firmware with non-ST MCUs?
2A.       The STM32 firmware can only be used with an ST MCU, except as may otherwise be  specifically permitted under terms of a license.
3Q.       Can I use modified STM32 firmware with non-ST MCUs?
3A.       Modified STM32 firmware can only be used with an ST MCU, except as may otherwise be specifically permitted under terms of a license.
4Q.       Can I modify STM32 firmware and redistribute it under my own copyright ?
4A.        Redistributions of modified STM32 firmware must retain the applicable copyright notice along with the applicable license conditions, except as may otherwise be specifically permitted under terms of a license.
5Q.      Can I be liable for copyright infringement If I distribute or use third-party firmware that is in violation of ST’s copyrights?
5A.       Yes, anyone using or redistributing third-party code that violates ST’s copyrights can also be liable for copyright infringement.
6Q.       If I download STM32 firmware from Github, am I free to use it as I wish?
6A.        No. All STM32 firmware is licensed under specific terms and conditions that must be complied with, regardless of the source.
7Q.       Can I use STM32 tools with non-ST MCUs?
7A.       The executable of STM32 tool can only be used with an ST MCU.
==================================THE END ==================================
回复于 2020-01-08 3#
回复于 2020-01-08 4#
回复于 2020-01-08 5#
回复于 2020-01-17 6#
刚开始的时候,GD确实用的是STM32的固件库。
回复于 2020-02-22 7#
回复于 2020-03-05 8#
学习了
回复于 2020-03-06 9#
回复于 2020-03-09 10#
有价值
