[分享] 一款完全防水的马达--水下推进器
651 查看
9 回复
 楼主 | 发布于 2020-01-02 | 只看楼主
新版水下电机外观,尺寸规格并没有改变,这个型号会成为我们持续维护、迭代的一个经典主打产品线。发生最大变革的是内部,采用了更有保障、优雅的新工艺。
No.
Item  项 目
Specification 规格
1
Motor construction电机构造
Permanent magnet, Core type永久磁石型
2
Number of phases相
3相
3
定子线圈连接类型Stator winding
Y connection
4
Number of magnet poles 磁铁磁极数
14
5
Number of core  poles 铁芯槽数
12
6
Resistance between coils相间电阻
Measure resistance betweenA1-A2, A2-A3, A3-A1 at core lead-wire  end at 20℃ 1.0Ω±15%  20℃测试
7
Inductance between coils相间电感
Measure Inductance betweenA1-A2, A2-A3, A3-A1 at core lead-wire  end at 20℃  285±30%mH   20℃测试
8
Appearance外 观
There shall be no excessive scratches, dents, or deformation, when inspected by naked eyes.目视不可有过多的划伤、压痕或变形
2.Rating
定 值
No.
Item  项 目
Specification 规格
1
Rated voltage额定电压
Vm=27.5V DC
2
Operating voltage使用电压范围
Vm=18~36 VDC
3
Direction of rotation 回转方向
CW&CCW 逆时针方向(从出力轴端看)
4
Position of motor马达放置状态
To be placed horizontally 以马达轴方基准水平方向固定
5
Operating temperature使用温湿度范围
+5 ~+50 ℃ 90%湿度 MAX
6
Storage temperature保存温度范围
-10~+60 ℃90%湿度 MAX
3.Measurement condition
   测定条件
1
Motor position马达放置状态
To be placed horizontally when measuring水平放置
2
Temperature range温度范围
Room temperature (25±10 ℃)  常温(25±10 ℃)If there is any doubt about the results, measurements shall be made Within 25±3 ℃.如果结果有任何的怀疑,应在:25±3 ℃测量。
3
Humidity range湿度范围
Room humidity (60±20%RH) If there is any doubt about the results, measurements shall be made Within 60±7%RH.如果有任何怀疑的结果,应在:60±7%RH测量。
4
Air pressure range气压范围
80Kpa~106Kpa
4.Motor Characteristics
    电机性能
No.
Item  项 目
Measurement condition  测定条件
Specification 规格
1
No load speed
无负荷转速
At rated voltage, no load.额定电压、无负荷。
7960±10% RPM290KV
2
No load current无负荷电流
Max:1.6A
3
Stator resistance
定子电阻
Interterminal  resistance 端子间电阻
 0.041±10% RPM
4
inductance
电感
Interterminal  resistance 端子间电感
50.6±10% μH
5
Insulation resistance
绝缘抵抗
Between all shorted pin of PCB and base plate 与底板间
Min:10MΩ/DC500V
6
Hi-Pot
绝缘耐压
At AC300V, 1sec and leakage current 1mA Max.AC300V, 1sec,泄漏电流1 mA以下。
7
Noise噪
DC 5 [V],No load, No controlled Distance between microphone ~ motor :0.4 [m]
55 [dB(A)] MAX.
8
Unbalance
动平衡
3200RPM
0.12[g・cm] Max
5.Reliability test
信赖性试验
No.
Item  项 目
1
Hightemperature Preservation test
高温保存试验
The motor preserved at 85℃,65%RH for 2 hours and then leave at room temperature for 2 hours, and then measure.85℃,65%RH条件下保存2Hr,常温放置24Hr后再测试。
2
Low temperature Preservation test
低温保存试验
The motor preserved at -40℃ for 2 hours and then leave at room temperature for 2 hours, and then measure.-40℃条件下保存2Hr,常温放置2Hr后再测试。
3
Humidity preservation test
高湿保存试验
The motor preserved at 65℃, 95%RH for 2 hours and then left at room temperature for 2 hours, and then measured.Not be dewy65℃,95%RH条件下保存2Hr,常温放置2Hr后再测试。要求无结露条件下
4
Temperature cycle test
温度循环试验
The motor shall be subject to 2 cycles, 1 cycle consist of +85℃, 65%RH~-40℃(1 hour each),and then leave at room temperature for 2 hours, and then measure.Not be dewy每周期:+85℃,65%RH ~ -40℃条件下各保存1Hr,共2个周期。常温放置2Hr后再测试。要求无结露条件下
No.
Item  项 目
NG Judgment
NG 判定基准
1
Guaranteed Life
保证寿命
Rated voltagecontrol Speed@7400RPM,Normal temperature
额定电压,制7400RPM,常温25℃
 马达堵转
产品平均无故障时间 MTBF≥1万小时
回复于 2020-01-02 沙发
有图片就更好了
回复于 2020-01-03 2#
感谢分享!!
回复于 2020-01-08 3#
回复于 2020-01-08 4#
回复于 2020-01-08 5#
回复于 2020-01-29 6#
回复于 2020-02-22 7#
回复于 2020-02-22 8#
回复于 2020-02-23 9#
