[官方资料] LCD驱动波形A类与B类的区别
2066 查看
 楼主 | 发布于 2019-11-20 | 只看楼主
        前两天,与同事讨论了一下关于LCD A类,B类驱动波形,结果发现当时理解错了。并而MC33P116上面画的图不是很明白。特意找了点资料重新学习了一下。现把几张波形图上传,供大家讨论:
发现我最近用IO模拟最多的波形就是1/2偏压,1/2占空比较的A类波形。
HC05核一段模拟lLCD驱动的代码。lcd_buffer[0]--lcd_buffer[3]为四个COM端需要显示的内容
switch(lcd_state)
  case 0:
             //com0 正亮
             P2 |=lcd_buffer[0]>>4;
             P1 =lcd_buffer[0]>>2;
             //将4个COM设置output
             COM0=0;
             reg_temp = P0CONH;   设置其它COM端口为高阻
             reg_temp &=0xfc;
             reg_temp |=0x02;
             P0CONH=reg_temp;
   break;
  case 1:
              //com0 负亮
               reg_temp =~lcd_buffer[0];
               P2 |=reg_temp>>4;
              P1 =reg_temp>>2;
             //将COM设置output
             COM0=1;
             reg_temp = P0CONH;
             reg_temp &=0xfc;
            reg_temp |=0x02;
            P0CONH=reg_temp;
   break;  case 2:
            //com1 a
            //com0 正亮
           P2 |=lcd_buffer[1]>>4;
           P1 =lcd_buffer[1]>>2;
          //将COM设置output
         COM1=0;
          P0CONL |=0X80;
  break;
  case 3:
            //com1 负亮
           reg_temp =~lcd_buffer[1];
          P2 |=reg_temp>>4;
             P1 =reg_temp>>2;
            //将COM设置output
           COM1=1;
           P0CONL |=0X80;
  break;
  case 4:
          //com2 正亮
          P2 |=lcd_buffer[2]>>4;
          P1 =lcd_buffer[2]>>2;
         //将4个COM设置output
         COM2=0;
         reg_temp = P2CONH;
          reg_temp &=0xf3;
         reg_temp |=0x08;
         P2CONH=reg_temp;
  break;
  case 5:
            //com2 负亮,
             reg_temp =~lcd_buffer[2];
           P2 |=reg_temp>>4;
           P1 =reg_temp>>2;
          //将COM设置output
           COM2=1;
           reg_temp = P2CONH;
           reg_temp &=0xf3;
            reg_temp |=0x08;
             P2CONH=reg_temp;
  break;
  case 6:
          //com3 正亮
         P2 |=lcd_buffer[3]>>4;
           P1 =lcd_buffer[3]>>2;
           //将4个COM设置output
            COM3=0;
         reg_temp = P2CONH;
            reg_temp &=0xfc;
          reg_temp |=0x02;
          P2CONH=reg_temp;
  break;
  case 7:
          //com3 负亮
          reg_temp =~lcd_buffer[3];
          P2 |=reg_temp>>4;
            P1 =reg_temp>>2;
          //将COM设置output
          COM3=1;
           reg_temp = P2CONH;
          reg_temp &=0xfc;
          reg_temp |=0x02;
            P2CONH=reg_temp;
  break;
  case 8:
         //将4个COM设置为LOW
            COM0=0;
           COM1=0;
           COM2=0;
           COM3=0;
          reg_temp = P2CONH;
          reg_temp &=0xf0;
           reg_temp |=0x0a;
          P2CONH=reg_temp;
          COM3=0;
          COM2=0;
          reg_temp = P0CONH;
          reg_temp &=0xfc;
          reg_temp |=0x02;
          P0CONH=reg_temp;
          COM0=0;
          reg_temp = P0CONL;
          reg_temp &=0x3f;
          reg_temp |=0x80;
          P0CONL=reg_temp;
          COM1=0;
         //P2 &=0XF0; //SEG LOW
           P1 =0;
           //lcd_set_buff(2,3);
   break;
  default:
    break;
if(lcd_state>=7)
       lcd_state=0;
else
      lcd_state++;
回复于 2019-11-21 沙发
回复于 2020-03-05 2#
