- 普通用户_2bef2c7c1027454
1 发帖0 回复105 积分
- 私信他 + 关注
[ 951.036218] usb 3-10: new full-speed USB device number 8 using xhci_hcd
[ 951.163659] usb 3-10: New USB device found, idVendor=0000, idProduct=0201, bcdDevice= 1.00
[ 951.163666] usb 3-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 951.163669] usb 3-10: Product: MV USB AUDIO
[ 951.163672] usb 3-10: Manufacturer: MVSILICON
[ 951.163674] usb 3-10: SerialNumber: 20130617A002
[ 951.166152] input: MVSILICON MV USB AUDIO as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10:1.3/0003:0000:0201.0003/input/input5
[ 951.218464] hid-generic 0003:0000:0201.0003: input,hidraw2: USB HID v2.01 Device [MVSILICON MV USB AUDIO] on usb-0000:00:14.0-10/input3
[ 951.791644] usb 3-10: current rate 44032 is different from the runtime rate 44100
[ 951.793401] usb 3-10: current rate 44032 is different from the runtime rate 44100
[ 951.795836] usb 3-10: Warning! Unlikely big volume range (=999), cval->res is probably wrong.
[ 951.795845] usb 3-10: [2] FU [PCM Playback Volume] ch = 2, val = 0/999/1
[ 951.797568] usb 3-10: Warning! Unlikely big volume range (=999), cval->res is probably wrong.
[ 951.797576] usb 3-10: [5] FU [Mic Capture Volume] ch = 2, val = 0/3996/4
[ 951.798308] usbcore: registered new interface driver snd-usb-audio
[ 2751.442084] usb 3-10: USB disconnect, device number 8
[ 2961.715702] usb 3-10: new full-speed USB device number 9 using xhci_hcd
[ 2961.842755] usb 3-10: New USB device found, idVendor=0000, idProduct=0201, bcdDevice= 1.00
[ 2961.842761] usb 3-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2961.842764] usb 3-10: Product: MV USB AUDIO
[ 2961.842767] usb 3-10: Manufacturer: MVSILICON
[ 2961.842769] usb 3-10: SerialNumber: 20130617A002
[ 2961.845140] usb 3-10: current rate 44032 is different from the runtime rate 44100
[ 2961.846550] usb 3-10: current rate 44032 is different from the runtime rate 44100
[ 2961.848678] usb 3-10: Warning! Unlikely big volume range (=999), cval->res is probably wrong.
[ 2961.848683] usb 3-10: [2] FU [PCM Playback Volume] ch = 2, val = 0/999/1
[ 2961.850351] usb 3-10: Warning! Unlikely big volume range (=999), cval->res is probably wrong.
[ 2961.850357] usb 3-10: [5] FU [Mic Capture Volume] ch = 2, val = 0/3996/4
[ 2961.851708] input: MVSILICON MV USB AUDIO as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10:1.3/0003:0000:0201.0004/input/input6
snd_usb_audio 352256 1
snd_usbmidi_lib 40960 1 snd_usb_audio
snd_hwdep 16384 1 snd_usb_audio
snd_rawmidi 40960 1 snd_usbmidi_lib
snd_seq 81920 0
snd_seq_device 16384 2 snd_seq,snd_rawmidi
snd_pcm 131072 1 snd_usb_audio
snd_timer 36864 2 snd_seq,snd_pcm
snd 102400 10 snd_seq,snd_seq_device,snd_hwdep,snd_usb_audio,snd_usbmidi_lib,snd_timer,snd_pcm,snd_rawmidi
[ 2961.903791] hid-generic 0003:0000:0201.0004: input,hidraw2: USB HID v2.01 Device [MVSILICON MV USB AUDIO] on usb-0000:00:14.0-10/input3
snd_seq 81920 0
soundcore 16384 1 snd
[johnfu@nas ~]$ aplay -l
aplay: device_list:275: no soundcards found...
有高手帮忙看看问题出在哪里吗?谢谢!
(0 )
(0 )
