- 普通用户_a692f388506b45c
16 发帖10 回复200 积分
- 私信他 + 关注
Breif introduction
IPQ6010 is a wireless communication SoC (system on chip) developed by Qualcomm Technologies, Inc. DR6018 is developed on the basis of a IPQ6010,it has strong performance,it can deal with various scenarios in people’s lives. It features wide variety of peripheral interfaces to maximize design flexibility across a full range of home networking products.
Specifications
a Quad-core ARM 64bit A53 @1.8GHz Processor
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
On-board 2x2 2.4GHz MUMIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
And the nor flash is 8-32MB(normally is 8MB),the nand flash is 256MB,the DDR is 1GB.
When we use DR6018,Notice these point.
The supply voltage is 24-48V
The operating temperature range is -40°C to +70°C,is equal to -104°F to +158°F
The storage temperature range is -45°C to +105°C,is equal to -113°F to +221°F
The operating humidity range is 5% to +95% (non-condensing)
Advantages
1.high performance.It has a quad-core ARM @1.8GHz Processor,it can improve its fluency, can also provide up to 16560 DMIPS computing power, built-in 6 multi-angle high gain antenna, 8 independent signal amplifier, to achieve 6600 megabit level of 160MH2 high frequency width.
2.strong memory.You will be able to run multiple applications at the same time smoothly.
3.fast data transmission speed.It comes with two 2.4GHz radios and two 5GHz radios with fast transmission speed and stability.
16 发帖10 回复200 积分
- 私信他 +关注
楼主 | 回复于 2023-03-08 沙发
If you want to learn more about the DR6018,welcome to click the link below.
PRODUCTS_Wallys Communications (Suzhou ) Co., LTD
The company utilizes its own professional knowledge and the top research and development team unceasingly breaks through, we have the hardware, the software, the RF, the antenna, the enclosure and so on design ability.
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,it also is one of the suppliers of the Facebook.
Email us by:sales5@wallystech.com
Visit our website:https://www.wallystech.com/
If you’re interested in learning more about these products, we will spare no efforts in endeavoring to be of service to you.
